| » Burner wont spark |
Model Number: JGBP35GEP3WG Brand: GE Age: More than 10 years
My front right burner will not spark. I switched it to the back and it worked. So im assuming i should change either the valve switch or valve control. Does anyone have any input before i order these parts. Id hate to order them and its something else. Thanks!!!!
Hi.
Check the burner switch for the continuity first.Unplug the unit, remove the wires from the switch. Set the switch in question to light position and using a multimeter see if there is continuity. No continuity - replace the switch Part number: WB24K14 Unfortunately the spark module's picture and it self are not available. I can't get you the part number but if you can post the picture of it we may get you the replacement if needed. Here are the breakdown diagrams and Burner Assembly parts for GE JGBP35GEP3 - AppliancePartsPros.com Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| jenn air burner wont spark | ajdemarco | Oven Repair (including Ranges and Cooktops) | 0 | 03-10-2012 09:40 AM |
| Spark on Igniter for top burner Spark is WEAK or sometimes NO spark!! | mobfather | Oven Repair (including Ranges and Cooktops) | 0 | 02-11-2011 10:10 AM |
| No spark at burner - is it spark module or switch? | Schoeman | Oven Repair (including Ranges and Cooktops) | 0 | 05-28-2010 01:18 PM |
| no spark at any burner | thorne electric | Oven Repair (including Ranges and Cooktops) | 1 | 11-19-2007 04:06 PM |
| One burner will not spark | bulldog217 | Oven Repair (including Ranges and Cooktops) | 1 | 09-29-2007 11:06 AM |
