| » Gas Oven Wont Stay Lit |
Hi.
Please provide the model number of the unit. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
For the test you will need the multimeter. When the oven display shows preheat what is the max temperature? At the bake ignitor connection with the oven set to bake check if there is 120VAC between two ignitor wires. If there is no voltage check the safety gas valve bake side for continuity (turn the power off). If you have proper voltage at the ignitor and it's not glowing - replace it. Here are the breakdown diagrams and Burner parts for Frigidaire FGF376CESB - AppliancePartsPros.com Simon. Next
__________________
Hi.
With the oven in Preheat and not actually heating check if there is 120VAC between two bake ignitor wires. If the voltage there - replace the ignitor. If not: check continuity of the safety gas valve (bake side of it). If there is no continuity - replace the valve. If there is continuity, check all wires for possible damage. What is the oven sensor resistance? The normal is about 1100 ohm at room temperature. Here are the breakdown diagrams and Burner parts for Frigidaire FGF376CESB - AppliancePartsPros.com Simon.
__________________
Quote:
So it appears the ignitor is ok (works for preheat) but gets no voltage when it goes to Bake. I am going to check the safety gas valve nefor continuity next as soon as I figure out where it is and which side is the bake side. Thanks alot! |
Hi.
Check the oven sensor as I suggested (1100 ohm at room temp.) One wire from bake ignitor is going to the gas valve. Check it only when oven fails to reignite. Looks like there is a problem with harness or connectors. Check the oven sensor at the control board disconnect plug. Simon.
__________________
I don't get much time to work on this, sorry. The temp sensor is fine 1060 ohms. I finally found the gas valve and the wire that connects to it from the ignitor. With power off I verified continuity btw the two terminals. I then set the oven to preheat and then same thing happened, after 5 minutes there was a click and the gas turned off. I quickly unplugged the stove and got to the gas valve to check countinuity btw the two terminals. It was wide open, i.e no continuity. After maybe 1-1/2 minutes the continuity came back. So (1) does the gas turn off because voltage is no longer getting to the gas valve and thus not to the ignitor also? Or (2) is something turning off the gas and then contacts open up in the gas valve so the ignitor doesn't keep glowing? I think its probably #1. If so something before the gas valve is turning off the voltage to the ignitor. I can't just keep replacing parts to try to find the problem, I want to know which part is not working and then replace it. Remember I just put a new control unit in this thing. Thanks for your help.
Hi.
Based on the info you provided the safety valve should be replaced Part number: 5303208499 Your scenario #1 is correct - when the winding inside the valve opens it's shots the gas immediately and cut the power to the ignitor. You can return any unused parts back to APP even if they been installed. Simon.
__________________
| Display Modes | |
| oven wont stay lit | MARIOD45 | Oven Repair (including Ranges and Cooktops) | 1 | 11-28-2012 03:46 PM |
| Oven wont stay lit | larimo | Oven Repair (including Ranges and Cooktops) | 0 | 09-21-2011 08:08 AM |
| oven wont stay lit and wont light after being lit | dethrowj | Oven Repair (including Ranges and Cooktops) | 0 | 08-06-2011 11:49 AM |
| oven wont stay lit | bearman65 | Oven Repair (including Ranges and Cooktops) | 1 | 12-28-2010 10:36 AM |
| Oven wont stay lit | hartracing | Oven Repair (including Ranges and Cooktops) | 0 | 12-20-2008 12:36 PM |
