| » Bake Element Replaced Still not Heating |
Model Number: 911 9344190 Brand: Kenmore Age: 1 - 5 years
I replaced the bake element in my Kenmore Range, hooked the element back up and still nothing. What's next?
Hi.
Pull out the range, take the back off, take one wire off the bake element (make sure it's not touching any metal surface). Turn the oven Bake on and check out each bake element's wire to the ground for 120VAC. Trace up the one without the voltage. Most likely it will lead you to the control board. Now the bad news - the control is no longer available. You can try to find somebody to rebuild the old one. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Replaced Bake element, now no heat from bake or broil | adambmoose | Oven Repair (including Ranges and Cooktops) | 1 | 08-14-2012 03:11 AM |
| Bake heating element not working after replaced | Kimmelko | Oven Repair (including Ranges and Cooktops) | 0 | 09-18-2010 10:11 AM |
| Replaced upper broil element, lower bake element. Elements still not working | bumdout | Oven Repair (including Ranges and Cooktops) | 1 | 11-25-2009 02:49 PM |
| Thermador dual fuel bake/heating element replaced, still not working | socalmat | Oven Repair (including Ranges and Cooktops) | 1 | 10-28-2009 01:03 PM |
| Replaced heating element now heating element nor broil element work, all else does | rontetley | Oven Repair (including Ranges and Cooktops) | 1 | 10-26-2009 01:30 PM |
