Discuss
Spark Control Module Replacement
 in
I believe the spark control module is bad on my range and need to get the part number off of
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Spark Control Module Replacement
  #1 (permalink)
Old 11-26-2012, 05:55 PM
Junior Member
sonnysmustang is on a distinguished road
Default Spark Control Module Replacement
Model Number: PG304   Brand: Thermador   Age: 5 - 10 years
I believe the spark control module is bad on my range and need to get the part number off of the module. Before I strip the nut on the burner base which is under the burner cover, I wanted to make sure it's the correct way to remove the burners. Also,is there a special tool since this looks like a very thin nut made out of soft metal at the top of a sleeve that goes down into the bottom of the burner.
Ads By Google
Related Models
Frigidaire PGF201HXD0 Wwh(v2) / Gas Range
Frigidaire PGF201HXD1 Wwh(v4) / Gas Range
Frigidaire PGF201HXD2 Wwh(v6) / Gas Range
Frigidaire PGF201HXD3 Wwh(v8) / Gas Range
Frigidaire PGF201HXD4 Wwh(v2) / Gas Range
Frigidaire PGF201HXW0 Wwh(v1) / Gas Range
Frigidaire PGF201HXW1 Wwh(v3) / Gas Range
Frigidaire PGF201HXW2 Wwh(v5) / Gas Range
Frigidaire PGF201HXW3 Wwh(v7) / Gas Range
Frigidaire PGF201HXW4 Wwh(v1) / Gas Range
Frigidaire PGF300HXW3 Wwh(v1) / Gas Range
Frigidaire PGF300HXW4 Wwh(v2) / Gas Range
Frigidaire PGF300HXW5 Wwh(v3) / Gas Range
Frigidaire PGF410HXD0 Wwh(v2) / Gas Range
Frigidaire PGF410HXD1 Wwh(v4) / Gas Range
Frigidaire PGF410HXD2 Wwh(v6) / Gas Range
Frigidaire PGF410HXD3 Wwh(v8) / Gas Range
Frigidaire PGF410HXD4 Wwh(v10) / Gas Range
Frigidaire PGF410HXW0 Wwh(v1) / Gas Range
Frigidaire PGF410HXW1 Wwh(v3) / Gas Range
Frigidaire PGF410HXW2 Wwh(v5) / Gas Range
Frigidaire PGF410HXW3 Wwh(v7) / Gas Range
Frigidaire PGF410HXW4 Wwh(v9) / Gas Range
Frigidaire PGF470HXD0 Wwh(v2) / Gas Range
Frigidaire PGF470HXD1 Wwh(v4) / Gas Range
Frigidaire PGF470HXD2 Wwh(v6) / Gas Range
Frigidaire PGF470HXD3 Wwh(v8) / Gas Range
Frigidaire PGF470HXD4 Wwh(v10) / Gas Range
Frigidaire PGF470HXW0 Wwh(v1) / Gas Range
Frigidaire PGF470HXW1 Wwh(v3) / Gas Range
Frigidaire PGF470HXW2 Wwh(v5) / Gas Range
Frigidaire PGF470HXW3 Wwh(v7) / Gas Range
Frigidaire PGF470HXW4 Wwh(v9) / Gas Range
Frigidaire PGF716HXD0 Wwh(v2) / Gas Range
Frigidaire PGF716HXD1 Wwh(v4) / Gas Range
Frigidaire PGF716HXD2 Wwh(v6) / Gas Range
Frigidaire PGF716HXD3 Wwh(v8) / Gas Range
Frigidaire PGF716HXD4 Wwh(v2) / Gas Range
Frigidaire PGF716HXW0 Wwh(v1) / Gas Range
Frigidaire PGF716HXW1 Wwh(v3) / Gas Range
Frigidaire PGF716HXW2 Wwh(v5) / Gas Range
Frigidaire PGF716HXW3 Wwh(v7) / Gas Range
Frigidaire PGF716HXW4 Wwh(v1) / Gas Range
Frigidaire PGLEF365EC1 Frigidaire Canada/electric Range
Frigidaire PGLEF365EC3 Frigidaire/range
Frigidaire PGLEF365ES1 Frigidaire/electric Range
Frigidaire PGLEF365ES2 Frigidaire Canada/electric Range
Frigidaire PGLEF365ES3 Frigidaire/range
Frigidaire PGLEF375ES1 Frigidaire/electric Range
Frigidaire PGLEF375ES2 Frigidaire Canada/electric Range
Frigidaire PGLEF375ES3 Frigidaire Canada/electric Range
Frigidaire PGLEF375ES4 Frigidaire/range
Frigidaire PGLEF375ES5 Frigidaire Canada/electric Range
Frigidaire PGLEF375GC1 Frigidaire Canada/electric Range
Frigidaire PGLEF384ES1 Frigidaire/electric Range
Frigidaire PGLEF384ES2 Frigidaire Canada/electric Range
Frigidaire PGLEF384ES3 Frigidaire/range
Frigidaire PGLEF385CB4 Frigidaire Canada/electric Range
Frigidaire PGLEF385CQ4 Frigidaire Canada/electric Range
Frigidaire PGLEF385CS4 Frigidaire Canada/electric Range
Frigidaire PGLEF385EB1 Frigidaire Canada/electric Range
Frigidaire PGLEF385EB2 Frigidaire Canada/electric Range
Frigidaire PGLEF385EB3 Frigidaire/range
Frigidaire PGLEF385EB4 Frigidaire Canada/electric Range
Frigidaire PGLEF385EC1 Frigidaire Canada/electric Range
Frigidaire PGLEF385EC3 Frigidaire/range
Frigidaire PGLEF385EC4 Frigidaire Canada/electric Range
Frigidaire PGLEF385EQ1 Frigidaire Canada/electric Range
Frigidaire PGLEF385ES1 Frigidaire Canada/electric Range
Frigidaire PGLEF385ES2 Frigidaire Canada/electric Range
Frigidaire PGLEF385ES3 Frigidaire/range
Frigidaire PGLEF385ES4 Frigidaire Canada/electric Range
Frigidaire PGLEF387CS4 Frigidaire/electric Range
Frigidaire PGLEF387CS5 Frigidaire/electric Range
Frigidaire PGLEF388CS4 Frigidaire/electric Range
Frigidaire PGLEF388CS5 Frigidaire/electric Range
Frigidaire PGLEF388ES1 Frigidaire/electric Range
Frigidaire PGLEF388ES2 Frigidaire Canada/electric Range
Frigidaire PGLEF388ES3 Frigidaire Canada/electric Range
Frigidaire PGLEF388ES4 Frigidaire/range
Frigidaire PGLEF388ES5 Frigidaire Canada/electric Range
Amana PGO-151 Range - S/c S/i Ddraft Gas
Amana PGO191 Surface Unit - Gas
Frigidaire PGP332LD3 Wwh(v1) / Gas Cooktop
Frigidaire PGP332LW3 Wwh(v2) / Gas Cooktop
Thermador PGR364GDZS
Thermador PGR364GLZS
Thermador PGR366ZS
Maytag PGR4100BDW Range - F/s Std Gas
Maytag PGR4102CDH Range - F/s Std Gas
Maytag PGR4102CDT Range - F/s Std Gas
Maytag PGR4202BDH Range - F/s Std Gas
Maytag PGR4202BDT Range - F/s Std Gas
Maytag PGR4305CDH Range - F/s Std Gas
Maytag PGR4305CDT Range - F/s Std Gas
Maytag PGR4310CDQ Range - F/s Std Gas
Maytag PGR4310CDW Range - F/s Std Gas
Maytag PGR4405CDH Range - F/s Std Gas
Maytag PGR4405CDS Range - F/s Std Gas
Maytag PGR4405CDT Range - F/s Std Gas
Maytag PGR4409ADH Range - F/s Std Gas
Maytag PGR4410ADQ Range - F/s Std Gas
Maytag PGR4410ADW Range - F/s Std Gas
Maytag PGR4410BDQ Range - F/s Std Gas
Maytag PGR4410BDW Range - F/s Std Gas
Maytag PGR4410CDQ Range - F/s Std Gas
Maytag PGR4410CDW Range - F/s Std Gas
Maytag PGR4420LDQ Range - F/s Std Gas
Maytag PGR4420LDW Range - F/s Std Gas
Maytag PGR5702BDH Range - F/s Std Gas
Maytag PGR5702BDT Range - F/s Std Gas
Maytag PGR5705BDH Range - S/c F/s Gas
Maytag PGR5705BDT Range - S/c F/s Gas
Maytag PGR5710BDC Range - S/c F/s Gas
Maytag PGR5710BDQ Range - S/c F/s Gas
Maytag PGR5710BDW Range - S/c F/s Gas
Maytag PGR5715BDQ Range - S/c F/s Gas
Maytag PGR5715BDW Range - S/c F/s Gas
Maytag PGR5720LDQ Range - S/c F/s Gas
Maytag PGR5720LDW Range - S/c F/s Gas
  #2 (permalink)
Old 11-27-2012, 05:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What seems to be a problem?
The model number you posted is incomplete or incorrect. Verify and repost it please.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 11-27-2012, 07:35 PM
Junior Member
Default Typo
Sorry for the typo. The correct model is PRG304.
  #4 (permalink)
Old 11-27-2012, 07:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Thank you for the correct model number.
Did you perform any troubleshooting? Why do you believe that the spark module is the culprit?
__________________
  #5 (permalink)
Old 11-28-2012, 01:34 PM
Junior Member
Default
The spark had been becoming intermittent for a couple of weeks since the multiple power outages we endured post Hurricane Sandy here in NY. Then the other night all four burners just quit. No spark, just gas. We've been lighting it the old fashioned way, with stick matches. I figure a power surge or spike took out the electronics. I did unplug the stove for a bit in the unlikely hope that it would miraculously start working! I can't troubleshoot any further until I can access the spark module, and that I believe requires removing the drip pans since it's shown in a box under the left side burners. I just can't get the venturi to budge with WD 40, box wreches, sockets, even vice grips.
I just consider it another of the many problems I've had with this overpriced stove that eats oven ignitors at least once a year, has had oven door problems and convection fan problems. Next breakdown will definitely prompt replacement. Thanks in advance for any advice you can offer.
  #6 (permalink)
Old 11-28-2012, 05:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Very likely the problem is a bad spark module but, before you will go further I would recommend to verify 120 VAC to the range.
Removing these venturies is a real headache. You can not force them too much because you can easy break the gas supply tubes. The best solution based on my experience is to cut off the venturies using a dremel tool. In such case you will need a new venturies and new jet holders.
Here are the breakdown diagrams and Parts for Thermador PRG304US - AppliancePartsPros.com
__________________
  #7 (permalink)
Old 11-28-2012, 06:58 PM
Junior Member
Default
Thanks for your help! I was afraid I might have to cut those. I have the dremel tool at the ready. Verified AC to the stove both by the fact that the oven does work and the oven light is on. Just to verify before I order, the et holders are listed in the parts list are burner bases? Not a stove guy so I just wanted to make sure. Second, is the 6 point re-igniter listed the correct part for my 4 burner unit with simmer control on the left burners? Thanks again
  #8 (permalink)
Old 11-28-2012, 07:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The jet holders are listed in the parts list "Burners & Grates" - #9. There is only one part number. If all burners are the same size then it's fine. If they are different, you better call APP CSR to verify it.
I found the 4 point re-igniter but I'm not sure if it will match up with the wire plug.
- The 4 point re-igniter Part number: 189323
Part number: 189323
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Spark Module replacement Billyk41 Oven Repair (including Ranges and Cooktops) 0 04-08-2011 07:51 AM
reconnect control module and spark module gonzo4926 Oven Repair (including Ranges and Cooktops) 0 11-03-2010 09:34 AM
spark module replacement part sands Oven Repair (including Ranges and Cooktops) 1 08-22-2009 10:33 PM
Spark Module Replacement Instructions majorpainintheask Oven Repair (including Ranges and Cooktops) 0 08-11-2009 09:52 AM
spark module replacement Mike R. Oven Repair (including Ranges and Cooktops) 0 11-12-2007 01:35 PM
