| » Ignitor/Safety valve problem?? |
Model Number: JGS968S0H3SS Brand: GE Age: 5 - 10 years
I kept on smelling gas while the oven was on so I figured I had an ignitor that went.. I replaced no problem... (thanks guys)
It worked for some time now, but I seem to have got another problem. There is too much gas being released in the oven when I first put it on. I motly hear a big whoosh and some times the door pots a bit. Is it the ignitor, the gas safety valve or something else. Any help would be appreciated Thanks Ads By Google Related Models |
Hello,
There are two igniters in the oven: Bake and Broil. Which one and when did you replace? Here are the breakdown diagrams and Parts for GE JGS968SH3SS Range - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Visually inspect the bake burner for any blocked and/or burned through flame holes. Make sure the igniter is properly aligned with the burner lighting holes.
If there is nothing wrong then most likely the igniter is bad. - The oven igniter Part number: WB13T10045 Gene.
__________________
The igniter and the burner tube should be parallel.
__________________
I have no idea. Average live time for oven igniter should be 2-3 years or even more.
__________________
Remove the oven floor and the flame spreader. You probably did it before when you replaced the igniter?
The normal reading should be more than 3.2 amps. Gene.
__________________
| Display Modes | |
| Gas Kenmore Oven, Ignitor or Valve Safety Arm? | Samiam13 | Oven Repair (including Ranges and Cooktops) | 3 | 03-29-2011 03:05 PM |
| magic chef ignitor replaced/possible safety valve | bigbearGreg | Oven Repair (including Ranges and Cooktops) | 0 | 03-09-2010 07:16 PM |
| Safety Valve Problem ? | rashaw | Oven Repair (including Ranges and Cooktops) | 1 | 05-05-2009 06:37 PM |
| GE XL44 Ignitor / burner / safety valve replacement | bhaughee | Oven Repair (including Ranges and Cooktops) | 2 | 04-22-2009 06:17 PM |
| Safety Valve problem ???? | T18CAPT | Oven Repair (including Ranges and Cooktops) | 1 | 07-30-2008 11:12 AM |
