| » Why did my range pigtail burn in half? |
Unplug the unit and check the terminal strip just to be sure it is OK.
If connections are corroded/pitted replace the terminal strip or clean them up with some fine sandpaper or emery cloth. It is important that the connection be noce and clean. The problem may have been in the unit from day one. Could have been a poor connector crimp or the connector was loose on the terminal strip. Both of these are a resistance so when current passes through the connection it heats up the wire. This then degrades the connection further so a little more resistance which is a little more heat and so on and so on till the connection fails. After replacing the line cord it would be a good idea to monitor the connection. Turn the stove on and let it run for 5 minutes or so to see if the connection heats up. If you have to touch the wire be sure to unplug the unit first. Try all the different modes for the unit. The reason is that on most units the black not only supplies power to the elements but also to the control board, lights, fans etc. (120 volts devices in the unit).
__________________
| Display Modes | |
| electric oven/gas range: loud bang, smell burn, broiler element dead | HouseTechnic | Oven Repair (including Ranges and Cooktops) | 1 | 03-05-2012 01:22 AM |
| Kenmore range - only half of double element works | kc7451 | Oven Repair (including Ranges and Cooktops) | 2 | 02-04-2012 03:28 PM |
| New rear tub half wont fit old front half | daaavey | Washer Repair | 0 | 10-23-2010 10:43 AM |
| GE Range, only half of burner works....... | FDAR | Oven Repair (including Ranges and Cooktops) | 0 | 11-01-2009 03:23 PM |
| Half of Jenn Air radiant range not working | glitch74 | Oven Repair (including Ranges and Cooktops) | 0 | 11-18-2008 01:00 PM |
