| » gas oven not heating |
What is the complete model number of the range?
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
There are two parts which could cause such problem: the relay board (more likely) and the main control board (less likely). Unfortunately both parts are no longer available.
__________________
Quote:
I don't think there is something wrong with the igniter because of the information shown on the display, but you can check it for continuity and measure the voltage to the igniter while the control calls for Bake. In case if I'm wrong and the problem is a bad igniter: - The igniter Part number: 492431 Gene.
__________________
In such situation the most important test is the voltage to the igniter. The normal reading should be about 120 VAC. Improper voltage reading proves a bad controls.
__________________
I also posted a bit of wrong information in my original post about the display. When I turn oven on and select bake then turn knob to 350 degrees. The display stays on preheat at 100 degrees it does not switch back and forth to bake. It just stays on preheat at 100 dergrees. Does this change the possible solution?
Yes, it definitely does. Check the voltage and the igniter resistance and post the results.
__________________
| Display Modes | |
| The oven won't heat up. The pilot is lit and not heating oven | Hazelave.corp | Oven Repair (including Ranges and Cooktops) | 1 | 11-21-2012 10:23 PM |
| Oven door opens when in use causing oven to stop heating | puck | Oven Repair (including Ranges and Cooktops) | 3 | 03-14-2009 07:25 AM |
| Bottom heating element in oven not heating | Bill Pitts | Oven Repair (including Ranges and Cooktops) | 1 | 03-07-2009 06:02 PM |
| Frigidaire Double Oven/ Top oven not heating | dross3491 | Oven Repair (including Ranges and Cooktops) | 6 | 12-14-2008 12:33 PM |
| GE Wall Double Oven Top Oven Not Heating | ryoung | Oven Repair (including Ranges and Cooktops) | 0 | 01-10-2008 08:02 PM |
