Discuss
Oven will not heat after self-cleaning!
 in
Please help! We recently tried the self-cleaning cycle on our Whirlpool Accubake oven, and we ended up having to stop
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven will not heat after self-cleaning!
  #1 (permalink)
Old 11-24-2012, 11:52 AM
Junior Member
Rugemistral is on a distinguished road
Unhappy Oven will not heat after self-cleaning!
Model Number: RBS305RDQ6   Brand: Whirlpool   Age: More than 10 years
Please help! We recently tried the self-cleaning cycle on our Whirlpool Accubake oven, and we ended up having to stop the cleaning midway because of the noxious fumes that were filling up our house. After it cooled down, we tried to open it, but the door would not open, so later we tried running the self-clean again, this time all the way through, and letting it cool down; even after that, the door still wouldn't open. Using the tiny tip of an ice pick, which I was able to slide down through a hole, I gently pushed down on the latch-hook to disengage it so I could open the door.
Now when I push "BAKE," it displays "350°F," as before, but if you push the up-arrow button, the temp. setting only goes down. If you push "START/ENTER," the display reads "PrE door" and it sounds like it's starting up (just like it sounded when it used to work), but the oven will not heat up at any temperature, even though the "running" sound continues.
Although it slides in, out, and around fairly freely, and doesn't seem jammed, I can't do anything with the latch or the door to make the "door" display go away. I've also tried to reset the controls by turning the circuit breakers off and on several times, but to no avail.
Any ideas? Suggestions would be most appreciated!!!
Ads By Google
Related Models
Whirlpool RBS307PDB1
Whirlpool RBS307PDB2
Whirlpool RBS307PDB4
Whirlpool RBS307PDQ1
Whirlpool RBS307PDQ2
Whirlpool RBS307PDQ4
Frigidaire RBSF117E1 BLACK Frg(v3) / Electric Cooktops and Control Box
Frigidaire RBSF117EL1 Frg(v2) / Electric Cooktops and Control Box
Frigidaire RBSF117EW1 Frg(v1) / Electric Cooktops and Control Box
Frigidaire RBSF129EL0 Frg(v4) / Electric Range
Frigidaire RBSF129EW0 Frg(v3) / Electric Range
Frigidaire RBUGCF95ED Frg(v6) / Wall Oven
Frigidaire RBUGCF95EK Frg(v7) / Wall Oven
Frigidaire RBUGCF95EW Frg(v5) / Wall Oven
Amana RC-10B Commercial Microwaves
Amana RC-10B-DD Commercial Microwaves
Amana RC-10B-PB Commercial Microwaves
Amana RC-10D Commercial Microwaves
Amana RC-10PB Commercial Microwaves
Amana RC-10S Commercial Microwaves
Amana RC-10SD Commercial Microwaves
Amana RC-10SE Commercial Microwaves
Amana RC-14 Commercial Microwaves
Amana RC-14B Commercial Microwaves
Amana RC-14S Commercial Microwaves
Amana RC-14SD Commercial Microwaves
Amana RC-14SE Commercial Microwaves
Amana RC-14T Commercial Microwaves
Amana RC-14TD Commercial Microwaves
Amana RC-14TE Commercial Microwaves
Amana RC-20 Commercial Microwaves
Amana RC-20SE Commercial Microwaves
Amana RC-6D Commercial Microwaves
Amana RC-6PB Commercial Microwaves
Amana RC-7D Commercial Microwaves
Amana RC-7PB Commercial Microwaves
Amana RC-8 Commercial Microwaves
Amana RC04880A1D Room Air Conditioner
Amana RC04880A1D REV Room Air Conditioner
Amana RC04880A1DR Room Air Conditioner
Amana RC04880A1DR REV Room Air Conditioner
Amana RC04880A1E Room Air Conditioner
Amana RC04880A1X Room Air Conditioner
Amana RC04880A1X REV Room Air Conditioner
Amana RC04880A1XR Room Air Conditioner
Amana RC04880A1XR REV Room Air Conditioner
Amana RC05010A1D Room Air Conditioner
Amana RC05010A1D REV Room Air Conditioner
Amana RC05010A1DR Room Air Conditioner
Amana RC05010A1DR REV Room Air Conditioner
Amana RC05080A1X Room Air Conditioner
Amana RC05080A1XR Room Air Conditioner
Amana RC05080M1D Room Air Conditioner
Amana RC05080M1D Rev Room Air Conditioner
Amana RC05080M1D Rev A Room Air Conditioner
Amana RC05080M1DR Room Air Conditioner
Amana RC05080M1DR Rev Room Air Conditioner
Amana RC05080M1DR Rev A Room Air Conditioner
Amana RC05090A1D Room Air Conditioner
Amana RC05090A1D REV Room Air Conditioner
Amana RC05090A1DR Room Air Conditioner
Amana RC05090A1DR REV Room Air Conditioner
Amana RC05090M1D Room Air Conditioner
Amana RC05090M1D Rev Room Air Conditioner
Amana RC05090M1D Rev A Room Air Conditioner
Amana RC05090M1DR Room Air Conditioner
Amana RC05090M1DR Rev Room Air Conditioner
Amana RC05090M1DR Rev A Room Air Conditioner
  #2 (permalink)
Old 11-24-2012, 07:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The model number you posted does not come up. Verify and repost it please.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 11-24-2012, 09:37 PM
Junior Member
Default
Quote:
Oops--sorry about that! It's RDS305PDQ6.
  #4 (permalink)
Old 11-24-2012, 09:38 PM
Junior Member
Default
Quote:
Scratch that, Gene--it's RBS305PDQ6.
(I was in such a hurry to correct my mistake that I mistyped again. Yes it's RBS305PDQ6.) Gene, do you think it might have to do with the door more than a blown thermal fuse?
Thanks.
Jeff ("Rugemistral")
  #5 (permalink)
Old 11-26-2012, 02:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Jeff,
You may want to start the troubleshooting from checking the door latch switches and the solenoid for continuity. If they are good then the problem is a bad control board which, unfortunately is no longer available.
- The micro switch (NC) Part number: 4452312
- The limit switch (NO) Part number: 4456568
- The solenoid Part number: 4451663
- The door latch assembly Part number: 4451424
Here are the breakdown diagrams and Parts for Whirlpool RBS305PDQ6 Wall Oven - AppliancePartsPros.com
__________________
  #6 (permalink)
Old 12-02-2012, 12:19 PM
Junior Member
Default
Thanks, Gene! Is there anything I should try before ordering parts and taking things apart?
Jeff
Hi Jeff,
  #7 (permalink)
Old 12-02-2012, 05:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Jeff,
Before ordering any part you have to do the troubleshooting as described earlier to determine which part to order.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't heat up after self cleaning cycle ToughTags Oven Repair (including Ranges and Cooktops) 1 02-28-2012 05:35 PM
Whirpool Oven won't heat up after self cleaning gsran Oven Repair (including Ranges and Cooktops) 30 03-23-2011 03:03 PM
Oven won't heat after self cleaning richemer Oven Repair (including Ranges and Cooktops) 1 07-03-2009 02:37 PM
Oven won't heat after self cleaning used FD21 Oven Repair (including Ranges and Cooktops) 4 06-28-2009 05:38 PM
Oven won't heat after using self cleaning cadams101 Oven Repair (including Ranges and Cooktops) 1 11-03-2008 04:40 AM
