The oven temp light (red) is no-longer visible on the panel - Does this require replacing the entire board @ $200 + or can I replace a bulb.
The model number you posted does not come up. Verify and repost it please.
Correct Model # is RDDS30
Originally Posted by: ianuzi ...The oven temp light (red) is no-longer visible on the panel... I'm assuming you meant that the digital display for the oven temperature has become dim. The correction in such situation is to replace the control board. Unfortunately this part has been discontinued and is no longer available. Try to do a web search for a companies who do repair on such parts. You can find the part number on the old control board. Gene.
