| » Electric Oven |
Model Number: PLCF489CCF Brand: Frigidaire Age: 1 - 5 years
This oven does not work on the convection setting. The fan doesn't come on, ever
I can't find any information on that model. It's probably a stuck relay on the EOC
Frigidaire 318010102 Clock/timer, Eoc - AppliancePartsPros.com ![]()
__________________
Ricks Appliance Repair |
Parts for Frigidaire PLCF489CCF Range - AppliancePartsPros.com Here is the wiring diagram http://manuals.frigidaire.com/prodin.../318045330.pdf If both the convection fan and the convection element do not come on then odds are that it is the control board. If the convection element works but the fan does not then it still could be the control board. But may also be a bad fan or a bad Auto Door Switch(Normally Open side not closing when the door is closed). Unfortunately I do not know where this switch is. They just show it at the end of the listing in the Body Parts section but do not show it in the parts breakdown. I am doing a bit of guessing that this is the switch as they do show the door switch as a separate item (12 and 12A). To confuse things just a little more they show 12A as a Door Switch ( 2 prong - has common and normally closed) but also show a item 12 as a Switch [3 prong -has a common and a normally open and normally closed (a bit of a guess on my part)]. So they may have combined the two switches. Perhaps rickgburton has some input on this. Or someone who has had this problem on this unit.
__________________
| Display Modes | |
| Amana electric oven. Broiler won't go on, temp not correct with oven | crome | Oven Repair (including Ranges and Cooktops) | 0 | 10-09-2011 03:17 PM |
| 27" electric double oven self clean w/erc111 & upper convection oven | sksmith | Oven Repair (including Ranges and Cooktops) | 0 | 12-22-2010 06:08 PM |
| Upper Oven Handle for GE Electric Oven | Oscar Sicola | Oven Repair (including Ranges and Cooktops) | 0 | 10-21-2009 07:42 PM |
| Oven lock switch on Jenn-Air electric oven | miriamgreen | Oven Repair (including Ranges and Cooktops) | 0 | 10-21-2009 01:40 PM |
| electric oven | VIN | Oven Repair (including Ranges and Cooktops) | 10 | 05-22-2008 09:05 PM |
