Discuss
oven flame cycles on and off quickly
 in
The oven burner will come on and light and then immediately turn off, then immediately light again, go off and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven flame cycles on and off quickly
  #1 (permalink)
Old 11-22-2012, 08:12 AM
Junior Member
fivesalone is on a distinguished road
Default oven flame cycles on and off quickly
Brand: Magic Chef   Age: 5 - 10 years
The oven burner will come on and light and then immediately turn off, then immediately light again, go off and on like this during the warm up time and cooking cycle. The flame continues to cycle constantly. This condition does not happen every time so when we call a repair person out it never happens while they are here. However, almost 80% of the time it happens to us. It seems the sensor is in the right place and it was even replaced once to see if that was the issue. Any help or suggestions/questions?
Ads By Google
  #2 (permalink)
Old 11-24-2012, 03:16 AM
Expert
APP Volunteer
rickgburton is on a distinguished road
Default
Replace the bake igniter.
__________________
Ricks Appliance Repair
  #3 (permalink)
Old 11-24-2012, 11:06 AM
Junior Member
Default
I understand your answer but why would we get the oven to work sometimes and then it acts up. I have replaced these on my furnace many times and they were broken thus interrupting any glow. Can these ignitors fracture and continue to work? Never had this happen before. My model CGR3740ADL does not pull up on the internet. Is there a generic ignitor for this model?
  #4 (permalink)
Old 11-24-2012, 11:31 AM
Expert
APP Volunteer
Default
The most common problem with gas ranges not heating properly or not turning on is the oven igniter. The oven or broil igniter may turn on and glow red and still be defective. The igniter(s) need to draw 3.2 to 3.6 amps to open the oven safety valve. Use an amp probe around one of the igniter wires to check the amps. If the igniter is not turning on use meter set to VAC and check for 110 VAC between the two igniter wires.
__________________
  #5 (permalink)
Old 12-01-2012, 03:43 PM
Junior Member
Default
Quote:
Today was my day to look at the oven. I replaced the igniter as you suggested and it did not help. I have the bottom plate out of the oven and the igniter glows and after a couple of minutes the flames comes on but is very weak. It flutters and goes out and then because the igniter is still glowing the gas comes on again very weakly and so on ............. It seems the igniter was not the problem so do you have another idea? Could the gas valve not be opened fully? Should the igniter glow the entire time the oven is warming up or maintaining heat?
  #6 (permalink)
Old 12-01-2012, 04:26 PM
Expert
APP Volunteer
Default
Yes, the igniter should stay on. If it's not the igniter the the oven safety valve is the only thing left.
__________________
  #7 (permalink)
Old 12-01-2012, 06:45 PM
Junior Member
Default
One more question, I hope. My model has a dual oven saftey valve
http://www.********.com/itm/MAYTAG-G...em4d0773 e535
If the safety valve is faulty wouldn't we have trouble with the burners on top of the oven? We don't have any trouble with the burners just with the oven. Do they operate seperately within that one safety valve? Thanks again.
  #8 (permalink)
Old 12-01-2012, 06:47 PM
Junior Member
Default
Part number 74006427
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge cycles quickly on/off then on again Jack Smith Refrigerator & Freezer Repair 2 02-04-2011 09:20 AM
Roper gas dryer cycles a few times fine then no flame Honey-Do Dryer Repair 0 08-25-2010 05:08 PM
flame cycles clothes wont dry jdebord56 Dryer Repair 0 08-04-2010 06:39 PM
Oven Flame Is Yellow And High. Flame Doesn't Regulate COOLJADE Oven Repair (including Ranges and Cooktops) 0 02-25-2010 03:28 PM
cycles on and off quickly repair50 Refrigerator & Freezer Repair 2 08-27-2009 05:00 PM
