Discuss
Timer-light-oven dead
 in
GE JBP 35W oven, oven light, oven timer and clock are all dead. They are all controlled from the single
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Timer-light-oven dead
  #1 (permalink)
Old 11-21-2012, 02:34 PM
Junior Member
Cigarjoe is on a distinguished road
Default Timer-light-oven dead
Brand: GE   Age: 5 - 10 years
GE JBP 35W oven, oven light, oven timer and clock are all dead. They are all controlled from the single circuit board. All other functions work correctly. Can anyone direct me to a schematic for the circuit board in this unit? I see no fuse, fuseable links or circuit breakers on the board. Any advice would be helpful. Thanks.
Joe
Ads By Google
  #2 (permalink)
Old 11-21-2012, 04:30 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Please provide complete model number of the oven.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 11-21-2012, 07:52 PM
Junior Member
Default
I'm sorry guys. The complete model number is:
JBP 35W 02WW GE Selfclean Electric Coil Range
  #4 (permalink)
Old 11-23-2012, 11:36 AM
Expert
Default
Hi.
Sorry, still can't find your model. Is it made for use in the USA?
Simon.
__________________
  #5 (permalink)
Old 11-23-2012, 02:27 PM
Junior Member
Default
It was purchased in Memphis, TN in 2004. Here is what I believe to be the correct info. I found these numbers on the unit myself (this time). Model : JBP 35 W H2WW Serial : VG266477Q Thanks for your help.
Joe
  #6 (permalink)
Old 11-23-2012, 04:41 PM
Expert
Default
Hi.
Use the multimeter to check if there is 240VAC at the control board contacts L1 and L2.
If the correct voltage present - replace the control board
Part number: WB27T11311
Simon.
__________________
  #7 (permalink)
Old 11-24-2012, 02:08 PM
Junior Member
Default
Thank you Simon, I'll check it. Have a good weekend.
Joe
  #8 (permalink)
Old 11-24-2012, 04:13 PM
Junior Member
Default
Simon, there is power to the board so I'll assume it's bad. The number on the board is WB2T10467. Is the WB27T11311 an exact replacement? Thanks.
  #9 (permalink)
Old 11-24-2012, 11:19 PM
Expert
Default
Hi.
If you mean WB27T10467 then it's the same part.
Simon.
__________________
  #10 (permalink)
Old 11-25-2012, 11:16 AM
Junior Member
Default
Great, thank you Simon. I'll order today. c/j
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven will not light, no light on control panel but timer works (Gene) Xray39 Oven Repair (including Ranges and Cooktops) 1 10-30-2011 09:42 AM
oven dead! only turn on inside light luferrei Oven Repair (including Ranges and Cooktops) 0 05-31-2011 06:08 PM
Surface Burners work OK, Oven dead, no control light turns on for oven Whirlyone Oven Repair (including Ranges and Cooktops) 0 06-07-2010 07:24 AM
Clock Timer dead jdpfamily Oven Repair (including Ranges and Cooktops) 1 02-13-2009 05:53 AM
Oven light and timer JHarding Oven Repair (including Ranges and Cooktops) 0 10-28-2008 03:58 PM
