Discuss
Kenmore Electric Range doesn't reach temperature
 in
My Kenmore slide in range does not reach preheat temperature. it takes an extremely long time and may reach 200
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Electric Range doesn't reach temperature
  #1 (permalink)
Old 11-21-2012, 01:13 PM
Junior Member
bilalian1 is on a distinguished road
Default Kenmore Electric Range doesn't reach temperature
Model Number: 629.46795894   Brand: Kenmore   Age: 5 - 10 years
My Kenmore slide in range does not reach preheat temperature. it takes an extremely long time and may reach 200 degrees at times, but sometimes not even that high. Broil works fine. I've replaced the lower element, and the thermostat, but the problem remains. I've tested the temperature sensor element, and it meets the resistance indicated on the site. What else could it be? The bottom element also does not appear to get hot. The cook-top works just fine
Ads By Google
Related Models
Kenmore 629.46796  ELECTRIC RANGE
Kenmore 629.46799  ELECTRIC RANGE
Jenn-Air 629.46965 Range - S/c S/i Ddraft Ele
Kenmore 629.46965  ELECTRIC RANGE
Jenn-Air 629.46969 Range - S/c S/i Ddraft Ele
Kenmore 629.46969  ELECTRIC RANGE
Kenmore 629.4697  ELECTRIC RANGE
Kenmore 629.46975  WIRING DIAGRAM-RANGE
Kenmore 629.46979  WIRING DIAGRAM-RANGE
Sears 629.69000  WHEEL KIT
Sears 629.69004  WHEEL KIT
Sears 629.69006  GASOLINE ENGINE KIT
Hardwick 629.70131 Range - F/s Std Gas
Kenmore 629.70131  GAS RANGE
Hardwick 629.70138 Range - F/s Std Gas
Kenmore 629.70138  GAS RANGE
Hardwick 629.70231 Range - F/s Std Gas
Kenmore 629.70231  GAS RANGE
Hardwick 629.70238 Range - F/s Std Gas
Kenmore 629.70238  GAS RANGE
Kenmore 629.756610  WALL FURNACE
Kenmore 629.756620  WALL FURNACE
Kenmore 629.756630  WALL FURNACE
Kenmore 629.756640  WALL FURNACE
Kenmore 629.756650  WALL FURNACE
Kenmore 629.756660  WALL FURNACE
Kenmore 629.756670  WALL FURNACE
Kenmore 629.756680  WALL FURNACE
Kenmore 629.756710  WALL FURNACE
Kenmore 629.756720  WALL FURNACE
Kenmore 629.756730  WALL FURNACE
Kenmore 629.756740  WALL FURNACE
Kenmore 629.756750  WALL FURNACE
Kenmore 629.756760  WALL FURNACE
Kenmore 629.756830  WALL FURNACE
Kenmore 629.756840  WALL FURNACE
Kenmore 629.756870  WALL FURNACE
Kenmore 629.756890  WALL FURNACE
Kenmore 629.756920  WALL FURNACE
Kenmore 629.756990  WALL FURNACE
Kenmore 629.776610  WALL FURNACE
Kenmore 629.776620  WALL FURNACE
Kenmore 629.776630  WALL FURNACE
Kenmore 629.776640  WALL FURNACE
Kenmore 629.776650  WALL FURNACE
Kenmore 629.776660  WALL FURNACE
Kenmore 629.776670  WALL FURNACE
Kenmore 629.776680  WALL FURNACE
Jenn-Air 629.80515 Misc / Accessory
Kenmore 629.80515  BACKSPLASH
Jenn-Air 629.80519 Misc / Accessory
Kenmore 629.80519  BACKSPLASH
Kenmore 629.90131  ELECTRIC RANGE
Kenmore 629.90138  ELECTRIC RANGE
Kenmore 629756810 GAS WALL FURNACE
Sears 629756811 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629756820 GAS WALL FURNACE
Sears 629756821 SEARS TOP VENT GAS-FIRED WALL FURNACE
Sears 629756831 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Sears 629756841 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629756850 GAS WALL FURNACE
Sears 629756851 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629756860 GAS WALL FURNACE
Sears 629756861 SEARS TOP VENT GAS-FIRED WALL FURNACE
Sears 629756871 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629756880 GAS WALL FURNACE
Sears 629756881 SEARS TOP VENT GAS-FIRED WALL FURNACE
Sears 629756891 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629756910 GAS WALL FURNACE
Sears 629756911 SEARS TOP VENT GAS-FIRED WALL FURNACE
Sears 629756921 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629776710 WALL FURNACE
Kenmore 629776720 WALL FURNACE
Kenmore 629776730 WALL FURNACE
Kenmore 629776740 WALL FURNACE
Kenmore 629776750 WALL FURNACE
Kenmore 629776760 WALL FURNACE
Kenmore 629776810 GAS WALL FURNACE
Sears 629776811 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629776820 GAS WALL FURNACE
Sears 629776821 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629776830 WALL FURNACE
Sears 629776831 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629776840 WALL FURNACE
Sears 629776841 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629776850 GAS WALL FURNACE
Sears 629776851 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629776860 GAS WALL FURNACE
Sears 629776861 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629776870 WALL FURNACE
Sears 629776871 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629776880 GAS WALL FURNACE
Sears 629776881 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629776890 WALL FURNACE
Sears 629776891 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629776910 GAS WALL FURNACE
Sears 629776911 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629776920 WALL FURNACE
Sears 629776921 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Magic Chef 62S14XAA Range - S/i Cont Clean Gas
Magic Chef 62S14XAS Range - S/i Cont Clean Gas
Magic Chef 62S14XAW Range - S/i Cont Clean Gas
Hoover 63 Frigidaire/electric Range
Amana 630.000 Mwave - Family Size (60 Hz)
Amana 630.001 Mwave - Family Size (60 Hz)
Amana 630.002 Range - S/c S/i Ddraft Gas
Amana 630.003 Range - S/c S/i Ddraft Gas
Amana 631.000 Range - S/c S/i Ddraft Gas
Amana 631.001 Range - S/c S/i Ddraft Gas
Amana 631.002 Range - S/c S/i Ddraft Gas
Amana 631.003 Range - S/c S/i Ddraft Gas
Amana 631.004 Range - S/c S/i Ddraft Gas
Amana 631.006 Range - S/c S/i Ddraft Gas
Amana 632-3J Room Air Conditioner
Hoover 634 Frigidaire/refrigerator
Hoover 64 Frigidaire/electric Range
Maytag 640C Dryer - Gas
Maytag 640W Dryer - Gas
Magic Chef 6458XRA Range - S/c S/i Gas
  #2 (permalink)
Old 11-21-2012, 01:25 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
HI.
The model number you posted doesn't come up. Please check and re post.
Use the multimeter to check if there is 240VAC across the bake element, if not - trace the wire with out 120VAC up.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 11-21-2012, 03:06 PM
Junior Member
Default Reply from Simon
Thanks Simon - I tested the voltage. Across the element itself, I get 6 to 9 volts. However when I test from either side (with the wires attached) to the third wire from the outlet, I get 126 VAC. If I test from either side of the element to the other power wire, I get 240VAC. If I disconnect the wires, the yellow wire on the left side of the bake element has 6 to 9 VAC. I traced this wire to the back of the front control panel. Does this mean the control panel is bad, or has a bad integrated component. Also, I have trouble pulling up that model number as well. On this site, I've found it listed without the last 3 digits. So, 629.46795 is what was displayed after the last time I searched for parts. It's the correct number though, trust me.
  #4 (permalink)
Old 11-21-2012, 05:38 PM
Expert
Default
Hi.
Based on the info you provided the control board should be replaced Part number: 5760M205-60
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool electric oven taking a long time to reach set temperature JW1 Oven Repair (including Ranges and Cooktops) 5 07-06-2012 07:34 PM
Dryer Does Not Reach Temperature ANDY M Dryer Repair 4 03-25-2010 08:19 PM
Oven does not reach set temperature dcmjcook Oven Repair (including Ranges and Cooktops) 0 03-07-2010 05:23 AM
Frigidaire electric range temperature fluctuations faisalmali Oven Repair (including Ranges and Cooktops) 2 11-26-2009 09:58 AM
Maytag electric range temperature problem AndreDW Oven Repair (including Ranges and Cooktops) 5 05-15-2009 06:27 PM
