Discuss
Five Star Duel Fuel Oven Problems
 in
Replaced the bake element. Now oven will not come on. I have good voltage on each element. Fan comes on.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Five Star Duel Fuel Oven Problems
  #1 (permalink)
Old 11-20-2012, 05:16 PM
Junior Member
menergy is on a distinguished road
Default Five Star Duel Fuel Oven Problems
Model Number: TTM525-BW   Brand: -other-   Age: More than 10 years
Replaced the bake element. Now oven will not come on. I have good voltage on each element. Fan comes on. Oven indicator light does not come on.
Ads By Google
Related Models
Whirlpool TU4000XMP0
Whirlpool TU4000XRP0
Whirlpool TU4000XRP1
Whirlpool TU4000XRP2
Whirlpool TU4000XRP3
Whirlpool TU4000XRPE
Whirlpool TU4100XTP0
Whirlpool TU4100XTP1
Whirlpool TU4100XTP2
Whirlpool TU4100XTP3
Whirlpool TU4700XBP0
Whirlpool TU4700XBP1
Whirlpool TU4700XXP0
Whirlpool TU4700XXP1
Whirlpool TU4700XXP2
Whirlpool TU8000XLP0
Whirlpool TU8000XRP0
Whirlpool TU8000XRP1
Whirlpool TU8000XRP2
Whirlpool TU8003XLP0
Whirlpool TU800SPDB0
Whirlpool TU800SPDB1
Whirlpool TU800SPDB2
Whirlpool TU800SPHB0
Whirlpool TU800SPJB0
Whirlpool TU800SPKB0
Whirlpool TU800SPKQ0
Whirlpool TU800SPPB0 Trash Compactor
Whirlpool TU800SPPB1 Trash Compactor
Whirlpool TU800SPPB2 Trash Compactor
Whirlpool TU800SPPQ0 Trash Compactor
Whirlpool TU800SPPQ1 Trash Compactor
Whirlpool TU800SPPQ2 Trash Compactor
Whirlpool TU8100XTP0
Whirlpool TU8100XTP1
Whirlpool TU8100XTP2
Whirlpool TU8100XTP3
Whirlpool TU8150XTP0
Whirlpool TU8150XTP1
Whirlpool TU8150XTP2
Whirlpool TU8700XXP0
Whirlpool TU8750XXP0
Whirlpool TU900QPDB0
Whirlpool TU900QPDQ0
Whirlpool TUD1000RB2 Undercounter Dishwasher
Whirlpool TUD2000W0
Whirlpool TUD2000W1
Whirlpool TUD2000W3
Whirlpool TUD2000W4
Whirlpool TUD2000W5
Whirlpool TUD2000W6
Whirlpool TUD2000W7
Whirlpool TUD2000Y0
Whirlpool TUD3000W0
Whirlpool TUD3000W1
Whirlpool TUD3000W2
Whirlpool TUD3000Y0
Whirlpool TUD3000Y1
Whirlpool TUD3000Y2
Whirlpool TUD3000Y3
Whirlpool TUD3000Y4
Whirlpool TUD3000Y5
Whirlpool TUD3000Y6
Whirlpool TUD4000EB0
Whirlpool TUD4000EB1
Whirlpool TUD4000EB2
Whirlpool TUD4700KB0
Whirlpool TUD4700KB1
Whirlpool TUD4700KQ0
Whirlpool TUD4700KQ1
Whirlpool TUD4700MQ0 Undercounter Dishwasher
Whirlpool TUD4700MQ1 Undercounter Dishwasher
Whirlpool TUD4700MQ2 Undercounter Dishwasher
Whirlpool TUD4700MU0 Undercounter Dishwasher
Whirlpool TUD4700MU1 Undercounter Dishwasher
Whirlpool TUD4700MU2 Undercounter Dishwasher
Whirlpool TUD4700SQ0 Undercounter Dishwasher
Whirlpool TUD4700SQ1 Undercounter Dishwasher
Whirlpool TUD4700SU0 Undercounter Dishwasher
Whirlpool TUD4700SU1 Undercounter Dishwasher
Whirlpool TUD5000Y0
Whirlpool TUD5000Y1
Whirlpool TUD5000Y2
Whirlpool TUD5000Y3
Whirlpool TUD5000Y4
Whirlpool TUD5700EQ0
Whirlpool TUD5700EQ2
Whirlpool TUD5700EQ3
Whirlpool TUD5700EQ4
Whirlpool TUD5700EQ5
Whirlpool TUD5700KB0
Whirlpool TUD5700KQ0
Whirlpool TUD5700MBO Undercounter Dishwasher
Whirlpool TUD5700MQ0 Undercounter Dishwasher
Whirlpool TUD6000JQ0
Whirlpool TUD6000KB1
Whirlpool TUD6000KQ1
Whirlpool TUD6000KT1
Whirlpool TUD6700KB0 Undercounter Dishwasher
Whirlpool TUD6700KQ0 Undercounter Dishwasher
Whirlpool TUD6700KS0 Undercounter Dishwasher
Whirlpool TUD6700KT0 Undercounter Dishwasher
Whirlpool TUD6700PB0 Undercounter Dishwasher
Whirlpool TUD6700PB2 Undercounter Dishwasher
Whirlpool TUD6700PQ0 Undercounter Dishwasher
Whirlpool TUD6700PQ2 Undercounter Dishwasher
Whirlpool TUD6700PS0 Undercounter Dishwasher
Whirlpool TUD6700PS2 Undercounter Dishwasher
Whirlpool TUD6700PT0 Undercounter Dishwasher
Whirlpool TUD6700PT2 Undercounter Dishwasher
Whirlpool TUD6710PB0 Undercounter Dishwasher
Whirlpool TUD6710PB1 Undercounter Dishwasher
Whirlpool TUD6710PB2 Undercounter Dishwasher
Whirlpool TUD6710PQ0 Undercounter Dishwasher
Whirlpool TUD6710PQ1 Undercounter Dishwasher
Whirlpool TUD6710PQ2 Undercounter Dishwasher
Whirlpool TUD6710PT0 Undercounter Dishwasher
Whirlpool TUD6710PT1 Undercounter Dishwasher
Whirlpool TUD6710PT2 Undercounter Dishwasher
Whirlpool TUD6710SB0 Undercounter Dishwasher
  #2 (permalink)
Old 11-21-2012, 05:00 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Following is the only info I could find on this manufacturer.
http://www.fivestarrange.com/public/...uct_manual.pdf
It does have a wiring diagram for a dual fuel unit but I have no idea if it is the same as your unit.
The elements look like they may have a hi-limit switch wired in series with them, perhaps it is open. I do not know where this is located so you will have to trace back the element wires to see if there is one.
Why did you replace the bake element?
Did you check the bake element with a meter?
was there a visible problem with the bake element.
Was the original problem that the bake element would not work but the broil element did work?
I am not sure what you mean.
If you have 240 volts across the element then it should heat up.
If you are checking to Neutral/ground and are seeing 120 volts then that really does not tell you much, it is the 240 volts that counts.
Also you did not say what the controls/setup was when you checked the voltage.
First I would check the power.
Next I would look for that hi-limit.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Looks like the fan runs off of half the line (120 volts)
But the oven on light needs 240 volts.
With luck someone else will jump in with info on this model or even experience with it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help converting a Dacor Duel Fuel Range bonniepadgett Oven Repair (including Ranges and Cooktops) 4 02-17-2012 03:12 PM
Kenmore Elite Duel Fuel Scott D Oven Repair (including Ranges and Cooktops) 0 06-01-2011 03:49 PM
JennAir duel fuel help jonesz1 Oven Repair (including Ranges and Cooktops) 1 08-08-2010 11:07 PM
Dacor Epicure Duel Fuel Range Problems Harvey@houseworksinc.com Oven Repair (including Ranges and Cooktops) 0 01-01-2009 11:22 AM
kenmore duel fuel elite range lizzzyt Oven Repair (including Ranges and Cooktops) 3 07-31-2008 07:32 PM
