Discuss
Oven Door Panel Glass Repacement
 in
The glass on my bottom oven was broken. I ordered a new door panel with glass and it has clear
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Door Panel Glass Repacement
  #1 (permalink)
Old 11-19-2012, 11:10 AM
Junior Member
Jody L is on a distinguished road
Red face Oven Door Panel Glass Repacement
Model Number: KEBC208KSS02   Brand: Kitchen Aid   Age: 5 - 10 years
The glass on my bottom oven was broken. I ordered a new door panel with glass and it has clear glass rather than small black lines running through it like the upper oven. The edges of the panel do not wrap around as far as the existing outer panel. I chatted with some one on line at this site and they said that the part I had order had been subbed in with a newer part that would work and that the manufacturer no longer produces on exactly like my other door.
Being a double oven I would like to match the upper door. I will check around to see if anyone has an older part but I was wondering could I remove the glass from the new door panel and just replace the glass? Will the foil heat tape be sufficient or is there some sort of adhesive used? Or better yet if I am just taking the glass from the new part could I have a piece of tempered glass cut to fit and save the cost of a whole new door panel?
Ads By Google
Related Models
Whirlpool KEBC208KSS02 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC208KSS03 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC208KSS04 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC208KSS1 30" Built - in Electric Double Oven Thermal Convect
Whirlpool KEBC208KWH0
Whirlpool KEBC208KWH02 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC208KWH03 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC208KWH04 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC208KWH1 30" Built - in Electric Double Oven Thermal Convect
Whirlpool KEBC247KBL0
Whirlpool KEBC247KBL02 24" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC247KBL03 24" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC247KBL04 24" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC247KBL05 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC247KBL06 24" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC247KBL2 24" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC247KSS03 24" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC247KSS04 24" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC247KSS05 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC247KSS06 24" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC247KWH0
Whirlpool KEBC247KWH02 24" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC247KWH03 24" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC247KWH04 24" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC247KWH05 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC247KWH06 24" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC247KWH2 24" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC276KBL0
Whirlpool KEBC276KBL02 27" Built - in Electric Self - Clean Double Oven
Whirlpool KEBC276KBL03 27" Built - in Electric Self - Clean Double Oven
Whirlpool KEBC276KBL04 27" Built - in Electric Self - Clean Double Oven
Whirlpool KEBC276KBL05 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC276KBL1
Whirlpool KEBC276KSS03 27" Built - in Electric Self - Clean Double Oven
Whirlpool KEBC276KSS04 27" Built - in Electric Self - Clean Double Oven
Whirlpool KEBC276KSS05 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC276KWH0
Whirlpool KEBC276KWH02 27" Built - in Electric Self - Clean Double Oven
Whirlpool KEBC276KWH03 27" Built - in Electric Self - Clean Double Oven
Whirlpool KEBC276KWH04 27" Built - in Electric Self - Clean Double Oven
Whirlpool KEBC276KWH05 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC276KWH1
Whirlpool KEBC277KBL0
Whirlpool KEBC277KBL02 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KBL03 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KBL04 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KBL05 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC277KBL1
Whirlpool KEBC277KBT0
Whirlpool KEBC277KBT02 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KBT03 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KBT04 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KBT05 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC277KBT1
Whirlpool KEBC277KSS03 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KSS04 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KSS05 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC277KWH0
Whirlpool KEBC277KWH02 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KWH03 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KWH04 27" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBC277KWH05 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC277KWH1
Whirlpool KEBC278HBL0
Whirlpool KEBC278HBL1
Whirlpool KEBC278HBL2
Whirlpool KEBC278HBL3
Whirlpool KEBC278HBT0
Whirlpool KEBC278HBT1
Whirlpool KEBC278HBT2
Whirlpool KEBC278HBT3
Whirlpool KEBC278HWH0
Whirlpool KEBC278HWH1
Whirlpool KEBC278HWH2
Whirlpool KEBC278HWH3
Whirlpool KEBC278KBL0
Whirlpool KEBC278KBL02 27" Built - in Electric Thermal Convection Double Oven
Whirlpool KEBC278KBL03 27" Built - in Electric Range Thermal Convection Double Oven
Whirlpool KEBC278KBL04 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC278KBL1
Whirlpool KEBC278KBS0
Whirlpool KEBC278KBS1
Whirlpool KEBC278KBT0
Whirlpool KEBC278KBT02 27" Built - in Electric Thermal Convection Double Oven
Whirlpool KEBC278KBT03 27" Built - in Electric Range Thermal Convection Double Oven
Whirlpool KEBC278KBT04 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC278KBT1
Whirlpool KEBC278KSS0
Whirlpool KEBC278KSS02 27" Built - in Electric Thermal Convection Double Oven
Whirlpool KEBC278KSS03 27" Built - in Electric Range Thermal Convection Double Oven
Whirlpool KEBC278KSS04 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC278KSS1
Whirlpool KEBC278KWH0
Whirlpool KEBC278KWH02 27" Built - in Electric Thermal Convection Double Oven
Whirlpool KEBC278KWH03 27" Built - in Electric Range Thermal Convection Double Oven
Whirlpool KEBC278KWH04 30" Built - in Electric Double Oven Self - Clean
Whirlpool KEBC278KWH1
Whirlpool KEBI100BBL0
Whirlpool KEBI100BBL1
Whirlpool KEBI100BBL2
Whirlpool KEBI100BBL3
Whirlpool KEBI100BWH0
Whirlpool KEBI100BWH1
Whirlpool KEBI100BWH2
Whirlpool KEBI100BWH3
Whirlpool KEBI100SBL0
Whirlpool KEBI100SBL1
Whirlpool KEBI100TBL1
Whirlpool KEBI100VBL0
Whirlpool KEBI100VBL1
Whirlpool KEBI100VBL2
Whirlpool KEBI100VBL3
Whirlpool KEBI100WBL0
Whirlpool KEBI100WWH0
Whirlpool KEBI100YBL0
Whirlpool KEBI100YBL1
Whirlpool KEBI100YBL2
Whirlpool KEBI100YBL3
Whirlpool KEBI100YWH0
Whirlpool KEBI100YWH1
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Glass panel in Whirlpool oven door swinging loose remorw Oven Repair (including Ranges and Cooktops) 0 06-28-2012 11:56 AM
replace glass panel on outer oven door danpatrick Oven Repair (including Ranges and Cooktops) 0 10-22-2011 01:03 PM
inner glass panel for oven door Equinunk1225 Oven Repair (including Ranges and Cooktops) 4 12-07-2010 02:49 PM
Glass oven door glass is dirty between the two glass mhobbs Oven Repair (including Ranges and Cooktops) 3 09-29-2010 09:17 AM
Replace inner glass panel on upper oven door gabaldini@gmail.com Oven Repair (including Ranges and Cooktops) 2 05-26-2010 07:22 AM
