Register | FAQ's | New Posts | Today's Posts | Extras |
» Intermittent Oven Problem |
![]() Model Number: KGSA906PSS00 Brand: Kitchen Aid Age: 5 - 10 years
![]() We're having an intermittent problem with our Kitchen Aid oven. About 6-7 months ago I replaced the gas valve and oven burner due to it not igniting. That solved that problem, but since we've had intermittent problems with the oven getting up to the proper temperature. Often it requires turning the oven off and on a few times to get it to warm to the desired temperature. When I test the spark module, the voltage readings are all correct. There is also at times a light smell of gas when using the oven that seems abnormal. Before I changed the gas valve and burner there had been a strong gas smell when turned on, but that went away after the parts replacement. Any help would be great. Thanks ZS Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Intermittent problem | jose408 | Washer Repair | 2 | 11-08-2011 04:29 PM |
intermittent Whirlpool oven problem | jackchaos | Oven Repair (including Ranges and Cooktops) | 10 | 03-25-2009 05:55 PM |
Intermittent Problem | matned | Microwave Repair | 17 | 03-05-2009 09:51 PM |
Intermittent Problem Igniting Oven | trhed6 | Oven Repair (including Ranges and Cooktops) | 0 | 12-31-2008 04:11 PM |
Intermittent Problem | reed2112 | Refrigerator & Freezer Repair | 5 | 12-28-2008 03:15 AM |
