Discuss
oven not shutting off
 in
replaced thermostat in oven. will not shut off. any possibility of defective part?
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven not shutting off
  #1 (permalink)
Old 01-31-2008, 08:11 PM
Junior Member
steve g is on a distinguished road
Default oven not shutting off
Brand: Kenmore   Age: More than 10 years
  #2 (permalink)
Old 02-01-2008, 12:11 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Steve,
In order to provide the most accurate advise I need the complete model number of the oven.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-02-2008, 10:17 AM
Junior Member
kenmore model 362. 75296790 ser 7v128380p
  #4 (permalink)
Old 02-02-2008, 12:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Steve,
If you replaced the oven thermostat with the brand new part
and the oven does not shut off, it could be the defective part or shorted wires to the oven igniter.
Check if the oven will go off with one of the wires disconnected from the oven thermostat.
If it would then you have to contact the place supplied the part for the warranty exchange.
Otherwise check the wires and the proper electrical connection at the power cord. The black wire should be connected to the hot line and the white wire should be connected to the neutral line.
- The part number for the oven thermostat is AP2623073
__________________
  #5 (permalink)
Old 02-03-2008, 09:08 AM
Junior Member
Default
It shuts off when you rotate the knob to the off position, but does not shut off when it reaches set temp. Wiring is fine.
  #6 (permalink)
Old 02-03-2008, 11:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Steve,
Most likely the oven thermostat is defective.
Who ever sold it has to exchange it under the warranty.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven keeps shutting off jstarin Oven Repair (including Ranges and Cooktops) 5 11-27-2009 03:32 PM
Oven keeps shutting down homebaker33 Oven Repair (including Ranges and Cooktops) 0 09-14-2009 09:33 AM
Oven Keeps Shutting off bwintrow@hotmail.com Oven Repair (including Ranges and Cooktops) 1 03-02-2009 05:11 PM
Dacor Oven Shutting off leeward Oven Repair (including Ranges and Cooktops) 1 10-30-2008 04:10 PM
