Discuss
electric slide-in range error f2e3
 in
getting error code f2e3, very difficult to clear. started today, oven cold, burners cold Ads By Google Related Models Whirlpool
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » electric slide-in range error f2e3
  #1 (permalink)
Old 11-14-2012, 12:55 PM
Junior Member
jfking is on a distinguished road
Default electric slide-in range error f2e3
Model Number: KESC307HBS   Brand: Kitchen Aid   Age: 5 - 10 years
Ads By Google
Related Models
Whirlpool KESC307HBS0
Whirlpool KESC307HBS1
Whirlpool KESC307HBS3
Whirlpool KESC307HBS4
Whirlpool KESC307HBS5
Whirlpool KESC307HBS6
Whirlpool KESC307HBS8
Whirlpool KESC307HBT0
Whirlpool KESC307HBT1
Whirlpool KESC307HBT3
Whirlpool KESC307HBT4
Whirlpool KESC307HBT5
Whirlpool KESC307HBT6
Whirlpool KESC307HBT8
Whirlpool KESC307HWH0
Whirlpool KESC307HWH1
Whirlpool KESC307HWH3
Whirlpool KESC307HWH4
Whirlpool KESC307HWH5
Whirlpool KESC307HWH6
Whirlpool KESC307HWH8
Whirlpool KESC307HWW4
Whirlpool KESC307HWW6
Whirlpool KESC307HWW8
Whirlpool KESC308LSS0 30" Slide - in Range Designer Style Convection Oven
Whirlpool KESH307BAL1
Whirlpool KESH307BAL2
Whirlpool KESH307BAL3
Whirlpool KESH307BAL4
Whirlpool KESH307BAL5
Whirlpool KESH307BAL6
Whirlpool KESH307BAL8
Whirlpool KESH307BAL9
Whirlpool KESH307BBL1
Whirlpool KESH307BBL2
Whirlpool KESH307BBL3
Whirlpool KESH307BBL4
Whirlpool KESH307BBL5
Whirlpool KESH307BBL6
Whirlpool KESH307BBL8
Whirlpool KESH307BBL9
Whirlpool KESH307BWH1
Whirlpool KESH307BWH2
Whirlpool KESH307BWH3
Whirlpool KESH307BWH4
Whirlpool KESH307BWH5
Whirlpool KESH307BWH6
Whirlpool KESH307BWH8
Whirlpool KESH307BWH9
Whirlpool KESH307GAL0
Whirlpool KESH307GAL1
Whirlpool KESH307GBL0
Whirlpool KESH307GBL1
Whirlpool KESH307GBS0
Whirlpool KESH307GBS1
Whirlpool KESH307GBT0
Whirlpool KESH307GBT1
Whirlpool KESH307GWH0
Whirlpool KESH307GWH1
Whirlpool KESH307HBL0
Whirlpool KESH307HBL1
Whirlpool KESH307HBL3
Whirlpool KESH307HBL4
Whirlpool KESH307HBL5
Whirlpool KESH307HBL6
Whirlpool KESH307HBS0
Whirlpool KESH307HBS1
Whirlpool KESH307HBS3
Whirlpool KESH307HBS4
Whirlpool KESH307HBS5
Whirlpool KESH307HBS6
Whirlpool KESH307HWH0
Whirlpool KESH307HWH1
Whirlpool KESH307HWH3
Whirlpool KESH307HWH4
Whirlpool KESH307HWH5
Whirlpool KESH307HWH6
Whirlpool KESI901PBL00 30" Slide - in Electric Oven
Whirlpool KESI901PBL01 30" Slide - in Electric Oven
Whirlpool KESI901PBS00 30" Slide - in Electric Oven
Whirlpool KESI901PBS01 30" Slide - in Electric Oven
Whirlpool KESI901PWH00 30" Slide - in Electric Oven
Whirlpool KESI901PWH01 30" Slide - in Electric Oven
Whirlpool KESK901SBL00 30" Slide - in Electric Oven
Whirlpool KESK901SSS00 30" Slide - in Electric Oven
Whirlpool KESK901SWH00 30" Slide - in Electric Oven
Whirlpool KESO140
Whirlpool KESO140S
Whirlpool KESO145
Whirlpool KESO145S
Whirlpool KESO170
Whirlpool KESO170S
Whirlpool KESO175
Whirlpool KESO175S
Whirlpool KESO176S
Whirlpool KESS300BAL0
Whirlpool KESS300BWH0
Whirlpool KESS907SBB00 30" Built - in Electric Oven
Whirlpool KESS907SBL00 30" Built - in Electric Oven
Whirlpool KESS907SSS00 30" Built - in Electric Oven
Whirlpool KESS907SWW00 30" Built - in Electric Oven
Whirlpool KESS908SPB00 30" Slide - in Electric Oven
Whirlpool KESS908SPS00 30" Slide - in Electric Oven
Whirlpool KESS908SPW00 30" Slide - in Electric Oven
Whirlpool KESV908PMT00 30" Slide - in Electric Oven Convection
Whirlpool KESV908PMT01 30" Slide - in Electric Oven Convection
Whirlpool KESV908PSS00 30" Slide - in Electric Oven Convection
Whirlpool KESV908PSS01 30" Slide - in Electric Oven Convection
Amana KET-480 Range - S/c S/i Ddraft Gas
Amana KET-480A Range - S/c S/i Ddraft Gas
Amana KET-480B Range - S/c S/i Ddraft Gas
Amana KET-480C Range - S/c S/i Ddraft Gas
Amana KET570 Surface Unit - Ele
Amana KET590 Surface Unit - Ele
Amana KET595 Surface Unit - Ele
Amana KET700 Surface Unit - Ele
Whirlpool KEWD105HBL0
Whirlpool KEWD105HBL05 30" Electric Built - in Warming Drawer
Whirlpool KEWD105HBL06 30" Electric Built - in Warming Drawer
Whirlpool KEWD105HBL1
  #2 (permalink)
Old 11-15-2012, 02:00 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for KESC307HBS - AppliancePartsPros.com
If you click on a parts picture often a new page will open with new info.
You seem to be missing a number at the end of the model number.
See the attachment for a tech sheet for a HBS3 unit.
The error is a shorted key.
Unplug the unit and the keyboard (console). Then plug the unit back in.
If the error is still there I would replace the microcomputer (control board/timer).
If there is no error then replace the console.
Make sure nothing can short out when you reapply power.
While apart I would try clean the connectors see below.
So also give a try with the console reconnected.
I doubt this will help as it is for an open ket not a shorted key error but is worth a try.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
  #3 (permalink)
Old 11-15-2012, 03:29 AM
Junior Member
Default thanks
thanks for your prompt response/suggestions
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore electric slide in range Stoiberj Oven Repair (including Ranges and Cooktops) 0 10-13-2011 03:43 PM
GE electric slide-in range Maryle Oven Repair (including Ranges and Cooktops) 0 05-01-2011 05:46 PM
Electric slide-in range Maryle Oven Repair (including Ranges and Cooktops) 0 04-28-2011 01:13 PM
GE Profile slide in electric range sneet Oven Repair (including Ranges and Cooktops) 0 01-15-2011 05:33 PM
F1 error on Amana slide in Range lmunson Oven Repair (including Ranges and Cooktops) 3 10-10-2008 09:19 PM
