| » Oven won't heat up but broiler works fine |
Model Number: CWE5800ACB Brand: Maytag Age: 5 - 10 years
The upper oven on my double wall oven has not heated properly since we lost power during Hurricane Sandy. The oven was on when the power blew out. The upper oven has a digital control panel. The broiler works fine, but when I set the oven to heat up on bake, it takes forever, and won't get above 250 degrees. The lower oven is fine. It has a dial control.
We think it is the bake element that needs to be replaced. Is that the likely cause? Or is there something else that might have happened? Thanks. Ads By Google Related Models |
Hello,
You will need a simple multimeter to check the Bake heating element for continuity. Replace it if there is no continuity. If the heating element is fine, replace the oven control board. - The Bake heating element Part number: Y04000066 - The control board Part number: 7601M286-60 Here are the breakdown diagrams and Parts for Maytag CWE5800ACB Wall Oven - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Oven won't heat, Stove works fine | Richard P | Oven Repair (including Ranges and Cooktops) | 1 | 06-08-2012 01:06 PM |
| Oven does not heat; Stovetop works fine | searsfamily | Oven Repair (including Ranges and Cooktops) | 1 | 07-02-2010 10:46 PM |
| Gas pulsating in oven. Broiler works fine. | TimW2 | Oven Repair (including Ranges and Cooktops) | 4 | 09-26-2009 05:43 PM |
| ignitor glows bright orange but no gas to oven, broiler works fine | browndeer | Oven Repair (including Ranges and Cooktops) | 2 | 08-07-2009 07:33 AM |
| Oven doesn't heat up, but broiler works fine | MichelleR | Oven Repair (including Ranges and Cooktops) | 1 | 01-21-2008 01:20 PM |
