Discuss
Tappan Automatic Pilotless Ignition wall oven
 in
I have an old Tappan Automatic Pilotless Ignition built in oven with the broiler below the oven. I have a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Tappan Automatic Pilotless Ignition wall oven
  #1 (permalink)
Old 11-10-2012, 05:06 PM
Junior Member
jmmulkey is on a distinguished road
Default Tappan Automatic Pilotless Ignition wall oven
Model Number: 12-1063-30   Brand: Tappan   Age: More than 10 years
I have an old Tappan Automatic Pilotless Ignition built in oven with the broiler below the oven. I have a model/Serial # of 12-1063-30/01134-15200234. My problem is that the temperature has started exceeding what we set the temp at, sometimes by as much as 25-50 degrees. I pulled off the temp knob to see if there was an adjustment/calibration type screw behind it, but didn't see anything like that. Any idea how you can calibrate this type of gas oven? Thank you for your help.
Related Models
Frigidaire 12-1063-45-04 Tap(v5) / Gas Range
Frigidaire 12-1063-45-05 Tap(v6) / Gas Range
Frigidaire 12-1063-57-04 Tap(v7) / Gas Range
Frigidaire 12-1063-57-05 Tap(v8) / Gas Range
Frigidaire 12-1063-66-04 Tap(v9) / Gas Range
Frigidaire 12-1063-66-05 Tap(v10) / Gas Range
Frigidaire 12-1263-00-01 Tap(v1) / Gas Range
Frigidaire 12-1263-23-01 Tap(v2) / Gas Range
Frigidaire 12-1263-45-01 Tap(v3) / Gas Range
Frigidaire 12-1263-57-01 Tap(v4) / Gas Range
Frigidaire 12-1263-66-01 Tap(v5) / Gas Range
Frigidaire 12-1663-00-01 Tap(v6) / Gas Range
Frigidaire 12-1663-23-01 Tap(v7) / Gas Range
Frigidaire 12-1663-45-01 Tap(v8) / Gas Range
Frigidaire 12-1663-57-01 Tap(v9) / Gas Range
Frigidaire 12-1663-66-01 Tap(v10) / Gas Range
Frigidaire 12-1863-00-01 Tap(v1)
Frigidaire 12-1863-00-02 Tap(v2)
Frigidaire 12-1863-00-03 Tap(v1) / Gas Wall Oven
Frigidaire 12-2299-00-01 Tap(v1) / Wall Oven
Frigidaire 12-2299-00-02 Tap(v1) / Wall Oven
Frigidaire 12-2299-00-03 Tap(v1) / Wall Oven
Frigidaire 12-2299-00-04 Tap(v2) / Wall Oven
Frigidaire 12-2299-00-06 Tap(v1) / Wall Oven
Frigidaire 12-2299-10-05 Tap(v1) / Wall Oven
Amana 12-2MW ROOM AIR CONDITIONER
Amana 12-2N ROOM AIR CONDITIONER
Amana 12-2NM ROOM AIR CONDITIONER
Frigidaire 12-3219-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-3699-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-3699-00-04 Tap(v1) / Gas Wall Oven
Frigidaire 12-3699-00-05 Tap(v1) / Gas Wall Oven
Frigidaire 12-3883-00-01 Tap(v11) / Gas Range
Frigidaire 12-3883-23-01 Tap(v12) / Gas Range
Frigidaire 12-3883-45-01 Tap(v13) / Gas Range
Frigidaire 12-3883-57-01 Tap(v14) / Gas Range
Frigidaire 12-3883-66-01 Tap(v15) / Gas Range
Frigidaire 12-3893-00-01 Tap(v11) / Gas Range
Frigidaire 12-3893-23-01 Tap(v12) / Gas Range
Frigidaire 12-3893-45-01 Tap(v13) / Gas Range
Frigidaire 12-3893-57-01 Tap(v14) / Gas Range
Frigidaire 12-3893-66-01 Tap(v15) / Gas Range
Amana 12-3G ROOM AIR CONDITIONER
Amana 12-3GH ROOM AIR CONDITIONER
Amana 12-3GM ROOM AIR CONDITIONER
Amana 12-3J ROOM AIR CONDITIONER
Amana 12-3JH ROOM AIR CONDITIONER
Amana 12-3JM ROOM AIR CONDITIONER
Frigidaire 12-4980-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-4980-00-03 Tap(v1) / Gas Wall Oven
Frigidaire 12-4980-00-04 Tap(v1) / Gas Wall Oven
Frigidaire 12-4980-00-05 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-02 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-03 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-04 Tap(v1) / Gas Wall Oven
Frigidaire 12-5063-00-04 Tap(v16) / Gas Range
Frigidaire 12-5063-00-05 Tap(v17) / Gas Range
Frigidaire 12-5063-23-04 Tap(v18) / Gas Range
Frigidaire 12-5063-23-05 Tap(v19) / Gas Range
Frigidaire 12-5063-45-04 Tap(v20) / Gas Range
Frigidaire 12-5063-45-05 Tap(v21) / Gas Range
Frigidaire 12-5063-57-04 Tap(v22) / Gas Range
Frigidaire 12-5063-57-05 Tap(v23) / Gas Range
Frigidaire 12-5063-66-04 Tap(v24) / Gas Range
Frigidaire 12-5063-66-05 Tap(v25) / Gas Range
Frigidaire 12-5299-00-01 Tap(v2) / Wall Oven
Frigidaire 12-5299-00-02 Tap(v1) / Wall Oven
Frigidaire 12-5299-00-04 Tap(v2) / Wall Oven
Frigidaire 12-6219-00-01 Tap(v2) / Gas Wall Oven
Frigidaire 12-6263-00-01 Tap(v16) / Gas Range
Frigidaire 12-6263-23-01 Tap(v17) / Gas Range
Frigidaire 12-6263-45-01 Tap(v18) / Gas Range
Frigidaire 12-6263-57-01 Tap(v19) / Gas Range
Frigidaire 12-6263-66-01 Tap(v20) / Gas Range
Frigidaire 12-6663-00-01 Tap(v21) / Gas Range
Frigidaire 12-6663-23-01 Tap(v22) / Gas Range
Frigidaire 12-6663-45-01 Tap(v23) / Gas Range
Frigidaire 12-6663-57-01 Tap(v24) / Gas Range
Frigidaire 12-6663-66-01 Tap(v25) / Gas Range
Frigidaire 12-6699-00-01 Tap(v2) / Gas Wall Oven
Amana 120.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 120.001 MWAVE - FAMILY SIZE (60 HZ)
Maytag 12001294 MISC / ACCESSORY
Maytag 12001302 MISC / ACCESSORY
Maytag 12001685 MISC / ACCESSORY
Maytag 12001686 MISC / ACCESSORY
Maytag 12001687 MISC / ACCESSORY
Maytag 12001688 MISC / ACCESSORY
Maytag 12001747 MISC / ACCESSORY
General Electric 1200L02 DISHWASHER
Thermador 1201
Thermador 1205
Jenn-Air 12103 SURFACE UNIT- DDRAFT GAS
Jenn-Air 12104 SURFACE UNIT- DDRAFT GAS
Roper 1213*2A GAS RANGE
Roper 1213*3A GAS RANGE
Roper 1213W1A GAS RANGE
Roper 1213Z2A GAS RANGE
Roper 1213Z3A GAS RANGE
Roper 1215*0A GAS RANGE
Roper 1215*1A GAS RANGE
Roper 1215W0A GAS RANGE
Roper 1215W1A GAS RANGE
Roper 1225*0A GAS RANGE
Roper 1225*1A GAS RANGE
Roper 1225*2A GAS RANGE
Roper 1225*3A GAS RANGE
Roper 1225W1A GAS RANGE
Roper 1225W2A GAS RANGE
Roper 1225W3A GAS RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
tappan gas wall oven mmeeks Oven Repair (including Ranges and Cooktops) 0 10-20-2010 05:29 PM
Pilotless Ignition stays on CheapMoney Oven Repair (including Ranges and Cooktops) 1 10-07-2010 01:33 PM
Burner wont come on - pilotless ignition is ok shassen@sisg.com Oven Repair (including Ranges and Cooktops) 0 02-01-2010 08:25 AM
Pilotless ignition not working dillmanj Oven Repair (including Ranges and Cooktops) 0 01-24-2010 04:31 PM
Tappan Wall Gas Oven Phil36 Oven Repair (including Ranges and Cooktops) 3 12-13-2008 06:36 AM
