| » No broiler in bottom oven. Ge Trutemp. |
Model Number: JKP45W)A2WW Brand: GE Age: More than 10 years
The bottom oven broiler is not working on my GE TruTemp. I believe I remember this happening on the top oven about 4 or 5 years ago, and I recall the technician said it was caused by an over temp, and simply required a reset. I tried to take the oven out of the wall, but it comes out as 1 whole unit and is very heavy. Is there some dolly or something I can put underneath it when I slide it out or is there a way to remove just the lower oven part and not the whole double oven structure?
Thanks for any and all help, and I promise to offer plenty of feedback. Joe in NY P.S. I called my local appliance repair shop and they can't come out until after Thanksgiving so that's why I'm looking to try myself. ![]() ![]() Ads By Google Related Models |
Hi.
Turn the power off and pull out as much as possible the broil element in question. Remove one wire off the contact and using the multimeter check the continuity of the element. If it's open - replace it Part number: WB44K5009 Here are the breakdown diagram and Body parts for GE JKP45WA2WW - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| can set bake temp however the broiler is on the whole time. Top burns bottom raw | humannnature | Oven Repair (including Ranges and Cooktops) | 1 | 12-02-2011 03:49 AM |
| Amana electric oven. Broiler won't go on, temp not correct with oven | crome | Oven Repair (including Ranges and Cooktops) | 0 | 10-09-2011 03:17 PM |
| Bottom oven, bottom heating element won't heat | weber7062 | Oven Repair (including Ranges and Cooktops) | 0 | 02-28-2011 02:38 PM |
| Bottom oven broiler won't turn off | Timmy3090 | Oven Repair (including Ranges and Cooktops) | 0 | 03-15-2010 05:53 PM |
| Bottom oven broiler not working | cavedog | Oven Repair (including Ranges and Cooktops) | 1 | 11-23-2008 09:44 AM |
