Discuss
Gas valve shorted?
 in
I measure zero volts across the valve terminals, even though the ignitor is glowing white hot. Could this be because
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas valve shorted?
  #1 (permalink)
Old 11-08-2012, 06:26 PM
Junior Member
charlesfred is on a distinguished road
Default Gas valve shorted?
Brand: Frigidaire   Age: 1 - 5 years
I measure zero volts across the valve terminals, even though the ignitor is glowing white hot. Could this be because there is a short in the gas valve? I removed the leads from the ignitor, and see just one ohm across the terminals. How can I definitely test the valve before ordering a replacement?
  #2 (permalink)
Old 11-09-2012, 06:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
This is not right place where to measure the voltage to the igniter. You have to do it at the same connections where the igniter wires were connected to and the oven control must be on at that time.
BTW, the complete model number of the oven is needed for more accurate advise.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 11-10-2012, 08:50 AM
Junior Member
Default
Gene, thank you so much for your reply! This problem is driving me crazy. The range is Kenmore 790.71202704. When the oven stopped working, I saw that the igniter was glowing a dull yellow. I replaced it, now I see a white-hot glow, but the oven still does not light. The top burners work fine.
  #4 (permalink)
Old 11-11-2012, 03:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Make sure the gas shut off handle (shown on the left side of the following picture) for the oven on the gas pressure regulator is On.
Slightly tap on the gas valve while the igniter is glowing. If the gas will start to flow, replace the gas safety valve.
- The gas valve Part number: 3203459
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
shorted out? toughkight Dryer Repair 3 02-12-2012 10:08 AM
Ref. Water Control Valve Question - Shorted? teddbere Refrigerator & Freezer Repair 3 03-31-2011 02:22 PM
Something shorted out mlbattl Dryer Repair 0 01-23-2011 05:39 PM
Shorted out Gas Valve DIYFIXit Oven Repair (including Ranges and Cooktops) 1 10-20-2010 03:35 PM
Shorted ERC robertglick Oven Repair (including Ranges and Cooktops) 0 04-23-2010 09:56 AM
