Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Whirlpool Accubake Electric Range (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/505769-whirlpool-accubake-electric-range.html)
RT White 11-06-2012 02:45 PM
HI,
My whirlpool range has an issue that while doing normal or convection baking the broiler will automatically turn on and send the temperature skyrocketing, without ever changing what is showing on the display - which burns up everything ....
Once you shut it off and try it again it starts normal, but after a few minutes it flips to broiler again.
Simon / APP Team 11-06-2012 04:52 PM
Hi.
Based on the info you provided it's a bad control board/clock that needs to be replaced Part number: W10157242
Here are the breakdown diagrams and Control Panel parts for Whirlpool GFE461LVQ0 - AppliancePartsPros.com
Post the results.
Simon.
RT White 11-06-2012 05:53 PM
What is the button sequence to push to bring up the service menu? I had tried it before and done a reset.
Simon / APP Team 11-07-2012 11:45 AM
Hi.
I don't think this control board has self repair feature.
You can try to unplug the oven for a few minutes and that doesn't help - replace the control.
Simon.
