| » whirlpool built in electric oven no power |
Model Number: RBS245PDT16 Brand: Whirlpool Age: 5 - 10 years
The booklet has 2002 on it. I did not install this oven, I purchased this home 3 years ago. I recently had the electric service to the house replaced, new electric box. The oven is the only item on a dble breaker. The box was replaced in July. Today is the first time I have used the oven since then, I baked cookies. I was just now putting the pans I keep in the oven back into it and discovered it has no power. The baking went fine. I went out to check the breaker box and the breaker was not tripped. I moved it to the right, then reset. Still no power to the oven. I am hoping that the breaker is bad. I have sent an email to the installing electrician tonight, a Sunday night. Can you suggest what else might be the cause? Thank you.
Parts for Whirlpool RBS245PDT16 Wall Oven - AppliancePartsPros.com See the attachment for the wiring diagram. I am assuming the clock/timer is totally dead. Hopefully it will be an electrical or oven hook-up problem. If not then odds are high that the control board (Item 3 in Control Panel Parts section) is blown.
__________________
THank you for your reply.
you do not mention the new elec box so I assume you do not think it is due to a faulty breaker? did I do something to cause this oven to lose power? j Quote:
No, it could be a bad beaker. did I do something to cause this oven to lose power? I do not think so.
__________________
Quote:
reply: the breaker is good, the power at the oven is good. Is the only other possibility Item 3 in the Control Panel Parts? Is this hard to replace on my own? |
Should not be too difficult.
Unfortunately I cannot fiond a manual for it. Here is the install info, perhaps it will be useful to you along with the parts breakdown diagrams. https://www.whirlpool.com/digitalass...0W10045010.pdf
__________________
| Display Modes | |
| Whirlpool Built in Electric Oven | lewisjilda | Oven Repair (including Ranges and Cooktops) | 2 | 08-13-2012 02:37 PM |
| Whirlpool Built-in Electric oven | Vayder | Oven Repair (including Ranges and Cooktops) | 1 | 02-19-2012 08:51 AM |
| Whirlpool Built-In oven no power | wrenschp | Oven Repair (including Ranges and Cooktops) | 1 | 02-08-2012 09:59 AM |
| Whirlpool Built-In Electric Oven | ndawg59 | Oven Repair (including Ranges and Cooktops) | 1 | 06-30-2009 07:25 PM |
| Whirlpool Built-in Electric Oven | Ktishler | Oven Repair (including Ranges and Cooktops) | 3 | 12-27-2008 07:18 PM |
