Discuss
Kenmore Max Oven Temp 290f Problem
 in
I have a Kenmore gas range model # 362.75585891. I'm having issues with my oven temperature control, I can turn
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Max Oven Temp 290f Problem
  #1 (permalink)
Old 11-03-2012, 10:53 AM
Junior Member
DanWiktor is on a distinguished road
Default Kenmore Max Oven Temp 290f Problem
Model Number: 362.75585891   Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore gas range model # 362.75585891. I'm having issues with my oven temperature control, I can turn the oven on by adjusting the dial, but I'm unable to get it higher that 290 deg.farenheit. It does not seam to matter if I set the dial to 300, 350, 400, 450, 500 the highest it will go is 290.I'm also unable to turn on the broiler. Back when this problem started I was able to mess with the oven dial control and if I held it just right it would show the proper temperature or ignite the broiler. My thoughts are that the mechanism for the oven temperature control dial has worn out and I need a whole new clock/control panel. Please provide any suggestions. I think this is the part I need to replace 183D6012P002 with a new WB27K10142. Are there any wiring problems when replacing with the new model, my original control had 4 cables connected? Any additional part I would need to order besides WB27K10142? Thanks.
Related Models
Magic Chef 3621WPA RANGE- F/S CONT CLEAN ELE
Magic Chef 3621WPW RANGE- F/S CONT CLEAN ELE
Magic Chef 3621WRA RANGE- F/S CONT CLEAN ELE
Magic Chef 3621WRW RANGE- F/S CONT CLEAN ELE
Magic Chef 3621XPA RANGE- F/S CONT CLEAN ELE
Magic Chef 3621XPW RANGE- F/S CONT CLEAN ELE
Magic Chef 3621XRA RANGE- F/S CONT CLEAN ELE
Magic Chef 3621XRW RANGE- F/S CONT CLEAN ELE
Magic Chef 3624XPA RANGE- F/S CONT CLEAN ELE
Magic Chef 3624XPW RANGE- F/S CONT CLEAN ELE
Magic Chef 3624XRA RANGE- F/S CONT CLEAN ELE
Magic Chef 3624XRW RANGE- F/S CONT CLEAN ELE
Amana 36261 REF - SXS/I&W
Kenmore 3626101190 GAS RANGE
Kenmore 3626101191 GAS RANGE
Kenmore 3626101192 GAS RANGE
Kenmore 3626101194 GAS RANGE
Kenmore 3626101195 GAS RANGE
Kenmore 3626101196 GAS RANGE
Kenmore 3626101197 GAS RANGE
Kenmore 3626101890 GAS RANGE
Kenmore 3626101891 GAS RANGE
Kenmore 3626101892 GAS RANGE
Kenmore 3626101894 GAS RANGE
Kenmore 3626101895 GAS RANGE
Kenmore 3626101896 GAS RANGE
Kenmore 3626101897 GAS RANGE
Kenmore 36261020101 GAS RANGE
Kenmore 36261020102 GAS RANGE
Kenmore 36261020103 GAS RANGE
Kenmore 36261021890 GAS RANGE
Kenmore 36261021891 GAS RANGE
Kenmore 36261021892 GAS RANGE
Kenmore 36261021893 GAS RANGE
Kenmore 36261021894 GAS RANGE
Kenmore 36261028890 GAS RANGE
Kenmore 36261028891 GAS RANGE
Kenmore 36261028892 GAS RANGE
Kenmore 36261028893 GAS RANGE
Kenmore 36261028894 GAS RANGE
Kenmore 36261061690 GAS RANGE
Kenmore 36261101000 ELECTRIC RANGE
Kenmore 36261101001 ELECTRIC RANGE
Kenmore 36261108000 ELECTRIC RANGE
Kenmore 36261108001 ELECTRIC RANGE
Kenmore 36261111699 KENMORE GAS RANGE
Kenmore 3626111190 GAS RANGE
Kenmore 3626111191 GAS RANGE
Kenmore 3626111192 GAS RANGE
Kenmore 3626111193 GAS RANGE
Kenmore 3626111194 GAS RANGE
Kenmore 3626111195 GAS RANGE
Kenmore 3626111196 GAS RANGE
Kenmore 3626111197 GAS RANGE
Kenmore 3626111198 GAS RANGE
Kenmore 36261118699 KENMORE GAS RANGE
Kenmore 3626111890 GAS RANGE
Kenmore 3626111891 Free Standing, Gas
Kenmore 3626111892 GAS RANGE
Kenmore 3626111893 Range (gas)*
Kenmore 3626111894 Range (gas)*
Kenmore 3626111895 GAS RANGE
Kenmore 3626111896 GAS RANGE
Kenmore 3626111897 GAS RANGE
Kenmore 3626111898 GAS RANGE
Kenmore 36261120101 GAS RANGE
Kenmore 36261120102 GAS RANGE
Kenmore 36261120103 GAS RANGE
Kenmore 36261120104 GAS RANGE
Kenmore 36261121890 GAS RANGE
Kenmore 36261121891 GAS RANGE
Kenmore 36261121892 GAS RANGE
Kenmore 36261121893 GAS RANGE
Kenmore 36261121894 GAS RANGE
Kenmore 36261121895 GAS RANGE
Kenmore 36261121896 GAS RANGE
Kenmore 36261128890 GAS RANGE
Kenmore 36261128891 GAS RANGE
Kenmore 36261128892 GAS RANGE
Kenmore 36261128893 GAS RANGE
Kenmore 36261128894 GAS RANGE
Kenmore 36261128895 GAS RANGE
Kenmore 3626121190 GAS RANGE
Kenmore 3626121191 Free Standing, Gas
Kenmore 3626121192 GAS RANGE
Kenmore 3626121193 GAS RANGE
Kenmore 3626121194 GAS RANGE
Kenmore 3626121890 GAS RANGE
Kenmore 3626121891 GAS RANGE
Kenmore 3626121892 GAS RANGE
Kenmore 3626121893 GAS RANGE
Kenmore 3626121894 GAS RANGE
Kenmore 3626125190 KENMORE GAS RANGE
Kenmore 3626125191 GAS RANGE
Kenmore 3626125192 GAS RANGE
Kenmore 3626125193 GAS RANGE
Kenmore 3626125890 GAS RANGE
Kenmore 3626125891 GAS RANGE
Kenmore 3626125892 GAS RANGE
Kenmore 3626125893 GAS RANGE
Kenmore 36261741000 ELECTRIC RANGE
Kenmore 36261741001 ELECTRIC RANGE
Kenmore 36261742000 ELECTRIC RANGE
Kenmore 36261742001 ELECTRIC RANGE
Kenmore 36261748000 ELECTRIC RANGE
Kenmore 36261748001 ELECTRIC RANGE
Kenmore 36262020300 GAS RANGE
Kenmore 36262020301 GAS RANGE
Kenmore 36262021300 GAS RANGE
Kenmore 36262021301 GAS RANGE
Kenmore 36262492000 ELECTRIC RANGE
Kenmore 36262492001 ELECTRIC RANGE
Kenmore 36262780100 ELECTRIC RANGE
Kenmore 36262780101 ELECTRIC RANGE
Kenmore 36262780102 ELECTRIC RANGE
Kenmore 36262780103 ELECTRIC RANGE
Kenmore 36262781000 ELECTRIC RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven temp. problem sjim Oven Repair (including Ranges and Cooktops) 4 03-18-2012 08:55 AM
Oven temp problem usmcmaddog Oven Repair (including Ranges and Cooktops) 0 06-08-2010 09:47 PM
GE oven temp problem Mike Meining Oven Repair (including Ranges and Cooktops) 0 04-11-2009 03:58 PM
oven temp problem StNick55 Oven Repair (including Ranges and Cooktops) 1 12-02-2008 09:54 AM
oven temp problem StNick55 Oven Repair (including Ranges and Cooktops) 1 11-25-2008 12:14 PM
