The auto ignition continues to spark after the oven burner has lit. Sometimes it will stop, but there is no patern to the length of time it may stay on. The pilot light does stay on as the oven cycles on and off relative to the temperature setting. Also of note, the burners on the stove top arc along with the one for the stove when it is turned on. I need a little more working knowledge to understand the problem.
