| » bake element replaced still wont work |
Model Number: s100 Brand: Jenn-Air Age: More than 10 years
I have a Jenn-Air s100 the baking element stopped working but the broil element still works. I replaced the baking element but it will still not heat up? What part do you think I need next to repair the problem?
Hi.
Please provide the complete model and serial number of the unit. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
Check the hi - limit thermostat most likely located at the back of the range. If there is no continuity - replace it Part number: 74009837 Post the results. Simon.
__________________
HI.
Make sure that the oven clock is set to the "manual", turn the knobs to pop out position or what ever it is per instructions to set the clock for MANUAL. If that is not the case than most likely it's the thermostat or the selector switch. Both this items are no longer available. Simon. P.S. You can return the hi - limit thermostat.
__________________
| Display Modes | |
| Replaced Bake element, now no heat from bake or broil | adambmoose | Oven Repair (including Ranges and Cooktops) | 1 | 08-14-2012 03:11 AM |
| Replaced bake element,but oven won't work | ant1828 | Oven Repair (including Ranges and Cooktops) | 1 | 02-20-2011 05:20 AM |
| Bake element wont work | Kizzie | Oven Repair (including Ranges and Cooktops) | 1 | 12-04-2010 04:15 AM |
| Replaced bake element and still will not work | OrwellMOM | Oven Repair (including Ranges and Cooktops) | 0 | 03-31-2010 06:00 PM |
| Replaced upper broil element, lower bake element. Elements still not working | bumdout | Oven Repair (including Ranges and Cooktops) | 1 | 11-25-2009 02:49 PM |
