Discuss
Thermador oven won't heat
 in
After beginning to preheat, the oven turns off and gives error code F 34. The oven can be turned on
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador oven won't heat
  #1 (permalink)
Old 11-01-2012, 09:22 AM
Junior Member
rbiermann is on a distinguished road
Default Thermador oven won't heat
Model Number: C271BS/02   Brand: Thermador   Age: 1 - 5 years
The oven can be turned on again and set to a new mode and temperature and will usually again turn off and give same code. After several attempts using different modes and temps, sometimes the oven will preheat to desired temp. and work. This is an electric oven. Very frustrating. Thanks.
Ads By Google
Related Models
Thermador C271U
Thermador C272U
Whirlpool C2757W0
Whirlpool C2757^0
Amana C28 Freezer - Chest
Amana C28B Freezer - Chest
Amana C28B-1 Freezer - Chest
Amana C28B-1-A Freezer - Chest
Amana C28B-1-C Freezer - Chest
Amana C28B-1-G Freezer - Chest
Amana C28B-1-L Freezer - Chest
Amana C28B-A Freezer - Chest
Amana C28B-C Freezer - Chest
Amana C28B-G Freezer - Chest
Amana C28B-L Freezer - Chest
Amana C28B1 Freezer - Chest
Amana C28B1L Freezer - Chest
Amana C28F Freezer - Chest
Amana C28F-A Freezer - Chest
Amana C28F-AG Freezer - Chest
Amana C28F-C Freezer - Chest
Amana C28W Freezer - Chest
Amana C28W-A Freezer - Chest
Amana C28W-AG Freezer - Chest
Amana C28W-C Freezer - Chest
Jenn-Air C300 Surface Unit - Ddraft Ele
Hoover C3003--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3003055 Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3005--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3005001 Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3005100 Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3007--- Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3007001 Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3007071 Coml - Access,burnisher,floor Mch,wet/dry
Hoover C3007100 Coml - Access,burnisher,floor Mch,wet/dry
Jenn-Air C301 Surface Unit - Ddraft Ele
Jenn-Air C301-C Surface Unit - Ddraft Ele
Thermador C301U
Jenn-Air C302 Surface Unit - Ddraft Ele
Thermador C302U
Whirlpool C3057X0
Whirlpool C3057^0
Jenn-Air C306 Surface Unit - Ddraft Ele
Jenn-Air C306-C Surface Unit - Ddraft Ele
Hoover C3077
Crosley C31000PAA Range - F/s Std Gas
Crosley C31000PAAD Range - F/s Std Gas
Crosley C31000PAT Range - F/s Std Gas
Crosley C31000PATP Range - F/s Std Gas
Crosley C31000PAW Range - F/s Std Gas
Crosley C31000PAWD Range - F/s Std Gas
Crosley C31000PAWP Range - F/s Std Gas
Crosley C31100PAA Range - F/s Std Gas
Crosley C31100PAV Range - F/s Std Gas
Crosley C31100SAA Range - F/s Std Gas
Crosley C31100SAAP Range - F/s Std Gas
Crosley C31100SAT Range - F/s Std Gas
Crosley C31100SATP Range - F/s Std Gas
Crosley C31100SAW Range - F/s Std Gas
Crosley C31100SAWP Range - F/s Std Gas
Crosley C31103SAA Range - F/s Std Gas
Crosley C31103SAT Range - F/s Std Gas
Crosley C31103SAW Range - F/s Std Gas
Crosley C31113WAA Range - F/s Std Gas
Crosley C31113WAAP Range - F/s Std Gas
Crosley C31113WAB Range - F/s Std Gas
Crosley C31113WAT Range - F/s Std Gas
Crosley C31113WATP Range - F/s Std Gas
Crosley C31113WAV Range - F/s Std Gas
Crosley C31113WAVP Range - F/s Std Gas
Crosley C31113XAA Range - F/s Std Gas
Crosley C31113XAT Range - F/s Std Gas
Crosley C31113XAW Range - F/s Std Gas
Crosley C31315VAM Range - F/s Std Gas
Crosley C31315VAV Range - F/s Std Gas
Crosley C31315VBM Range - F/s Std Gas
Crosley C31315VBQ Range - F/s Std Gas
Crosley C31315VBV Range - F/s Std Gas
Crosley C31315XBT Range - F/s Std Gas
Crosley C31315XBW Range - F/s Std Gas
Whirlpool C3157W0
Whirlpool C3157^0
Jenn-Air C316 Surface Unit - Ddraft Ele
Jenn-Air C316-C Surface Unit - Ddraft Ele
Jenn-Air C316B Surface Unit - Ddraft Ele
Jenn-Air C316B-C Surface Unit - Ddraft Ele
Jenn-Air C316W Surface Unit - Ddraft Ele
Jenn-Air C316W-C Surface Unit - Ddraft Ele
Whirlpool C3257W0
Whirlpool C3257^0
Whirlpool C3357^0
Whirlpool C3408B0
Whirlpool C3408B1
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help! Thermador Oven Won't Heat! SPC548 Oven Repair (including Ranges and Cooktops) 2 01-12-2011 11:30 PM
Thermador Oven won't heat up mommyoven Oven Repair (including Ranges and Cooktops) 2 11-11-2009 05:43 PM
Thermador Oven will not heat westillustration Oven Repair (including Ranges and Cooktops) 0 11-11-2009 11:06 AM
Thermador gas oven will not heat mbasboll Oven Repair (including Ranges and Cooktops) 0 10-23-2009 08:43 AM
Thermador Oven No Heat trebor Oven Repair (including Ranges and Cooktops) 0 01-05-2009 12:17 PM
