| » Burner not heating |
Model Number: 91195579891 Brand: Kenmore Age: More than 10 years
Right front burner will not heat and the element on indicator light stays on all the time. Checked the element itself and it tests good. I'm thinking either the element switch or the thermal switch or both. Not sure how to check these two parts out. Can anyone help?
Hi.
Unplug the range. Get access to the burner switch from the back. Locate contacts H1 and H2 at the switch, turn the switch on, restore the power and using the multimeter check for 240VAC between those contacts. If there is proper voltage - replace the element, if no voltage - replace the switch. For small burner switch p/n WB23M24. for the large one - WB23M23. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
You are welcome.
Simon.
__________________
| Display Modes | |
| Top burner heating element too hot | Shell1370 | Oven Repair (including Ranges and Cooktops) | 1 | 11-03-2011 02:35 PM |
| burner heating up while not turned on | BK1234 | Oven Repair (including Ranges and Cooktops) | 1 | 08-04-2011 03:25 AM |
| Burner not heating properly, fan wiring? | Veem | Oven Repair (including Ranges and Cooktops) | 0 | 02-01-2010 12:28 PM |
| Cooktop burner stops heating | jlk3403 | Oven Repair (including Ranges and Cooktops) | 0 | 08-12-2009 09:29 AM |
| Stove Top front burner not heating | Ribbons75 | Oven Repair (including Ranges and Cooktops) | 3 | 01-25-2009 01:40 PM |
