| » Sears Kenmore Pro Dual Fuel Range Problem Up |
Model Number: 79079523603 Brand: Sears Age: 1 - 5 years
After setting the oven control knob to Bake and setting the temperature knob to the desired cooking temperature, the oven will initially try to heat up, but after a minute or so, will display ERR code and stop. While it attempts to heat up,the displayed set temperature fluctuates and it beeps constantly. Is there a control board that needs replaced?
Did you try to change to another function, using the Function knob without turning it off first?
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Gene,
Thanks for the reply. No, I set the function knob to Bake, set the temperature, and within a few minutes get the ERR on the display. I can get it to work if I select Conv Bake sometimes. I am just trying to figure out what needs to be replaced to fix this issue. This is very frustrating. |
Sounds like the problem is a bad oven control board but there is a chance for the function switch to be bad as well. I could not find any detailed troubleshooting instructions. You may want to call Sears for more specific diagnosis.
__________________
__________________
| Display Modes | |
| Sears Kenmore Pro Dual Fuel Range Problem Heating Up | akkelley3 | Oven Repair (including Ranges and Cooktops) | 6 | 11-02-2012 05:54 PM |
| Kitchenaid dual fuel rANGE HAS pf RESET PROBLEM | Oregonia | Oven Repair (including Ranges and Cooktops) | 0 | 06-22-2012 10:03 AM |
| kenmore pro dual fuel range overheating | kenmoreprofails | Oven Repair (including Ranges and Cooktops) | 7 | 05-10-2012 04:37 AM |
| Bosch Dual Fuel range Meat Probe problem | jayhawk2685 | Oven Repair (including Ranges and Cooktops) | 0 | 08-22-2009 08:16 AM |
