Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Sears Kenmore Pro Dual Fuel Range Problem Up (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/505145-sears-kenmore-pro-dual-fuel-range-problem-up.html)
akkelley3 10-31-2012 06:38 PM
After setting the oven control knob to Bake and setting the temperature knob to the desired cooking temperature, the oven will initially try to heat up, but after a minute or so, will display ERR code and stop. While it attempts to heat up,the displayed set temperature fluctuates and it beeps constantly. Is there a control board that needs replaced?
Gene 11-01-2012 02:06 PM
Did you try to change to another function, using the Function knob without turning it off first?
akkelley3 11-02-2012 05:48 PM
Gene,
Thanks for the reply. No, I set the function knob to Bake, set the temperature, and within a few minutes get the ERR on the display. I can get it to work if I select Conv Bake sometimes. I am just trying to figure out what needs to be replaced to fix this issue. This is very frustrating.
Gene 11-02-2012 06:31 PM
Sounds like the problem is a bad oven control board but there is a chance for the function switch to be bad as well. I could not find any detailed troubleshooting instructions. You may want to call Sears for more specific diagnosis.
akkelley3 11-03-2012 06:19 AM
Thanks for the quick response Gene. I'll check with Sears.
Gene 11-03-2012 04:08 PM
