| » Top oven will not heat |
Model Number: WW30430W Brand: Jenn-Air Age: More than 10 years
Symptoms:
Top oven will not heat in any mode or temperature setting. The display will read 100, but the elements will not activate. However, if the bottom oven has been on for a period of time, the top oven will work in all modes and temperature settings. Last week I was able to activate the clean mode, by the procedure described above, but it did not aleviate the problem. I have noticed the touch pad becoming more difficult to use - more pressure is needed to activate; however, I do not know if this is related to the problem. Any suggestions will be greatly appreciated. Richard Ads By Google Related Models |
Hi.
Locate the hi - limit thermostat behind the control panel on the left. Check if it's open (no continuity). Replace if needed Part number: 71001844 Here are the breakdown diagrams and Internal Controls parts for Jenn-Air WW30430W - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| No heat and leads to oven heat element only showing 110volts | nobull1466 | Oven Repair (including Ranges and Cooktops) | 7 | 06-07-2012 11:23 AM |
| Oven won't heat up to pre-heat setting | tmilam | Oven Repair (including Ranges and Cooktops) | 0 | 04-24-2011 04:48 PM |
| Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat | dsumption | Oven Repair (including Ranges and Cooktops) | 3 | 04-04-2011 05:03 PM |
| Wall oven will not heat/re-heat properly | dottavio | Oven Repair (including Ranges and Cooktops) | 0 | 01-07-2010 09:47 AM |
| Oven/clock Control Panel is no longer lit but oven does heat. | jthomas@abrakadoodle.com | Oven Repair (including Ranges and Cooktops) | 1 | 12-05-2009 04:07 PM |
