Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Both elements won't work & the number 20 displays upon power up. (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/504978-both-elements-wont-work-number-20-displays-upon-power-up.html)
mrtexaz3 10-30-2012 01:05 AM
The bake and broil element won't come on. I've tested both elements and both are good. I've tested the long oven control and it's good. I've tested the 240/120 volts and it's good. I've unplugged the oven for several minutes while performing the above tests and have noticed that when I plug the oven back in the oven digital display flashes the number "20" for a few seconds and then goes off and then displays the clock time.
My questions are:
----- Question #1) What do you think could be the problem (I think the problem is the printed circuit display board is bad somehow), but please tell me what you think it could be??
----- Question #2) What is the number "20" that's displayed mean when I initially plug the oven in?
Thanks ahead of time for helping me with these problems.
Gene 10-30-2012 02:35 PM
Quote:
Originally Posted by mrtexaz3 (Post 778314)
My questions are:
1. You are on the right track. If there is nothing wrong with the heating elements and/or the wires to them, then the problem is a bad control board.
2. I have no idea what it means. There are no such error code listed for this range.
- The control board Part number: 5701M760-60
Here are the breakdown diagrams Parts for Maytag MERH752BAB Range - AppliancePartsPros.com
