Discuss
replace GE oven element
 in
Is it fairly easy to replace an element on a GE oven where there appears to be rachets screws holding
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » replace GE oven element
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-31-2008, 11:13 AM
kathyb kathyb is offline
Junior Member
kathyb is on a distinguished road
Default replace GE oven element
Model Number: JKP44   Brand: GE   Age: More than 10 years
Is it fairly easy to replace an element on a GE oven where there appears to be rachets screws holding in the prongs? Do you just unscrew the nuts and will the prongs release? then you insert the new element and retighten the nuts?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-31-2008, 04:08 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Remove the screws holding the heat element and carefully pull it out as far as the wires go.
Remove the wires from the heating element terminals and attach them to the new heating element.
Install the heating element back and screw it in place.
If you need the right part number for the heating element - post the complete model number of the oven.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 05-16-2008, 09:19 AM
MARCIA.MCRAE@VA.GOV MARCIA.MCRAE@VA.GOV is offline
Junior Member
MARCIA.MCRAE@VA.GOV is on a distinguished road
Default
What Do You Use To Unscrew The Bolts Holding The Burner In?
  #4 (permalink)
Old 05-16-2008, 09:20 AM
Junior Member
Default
[quote=MARCIA.MCRAE@VA.GOV;21944]What Do You Use To Unscrew The Bolts Holding The Burner In?IS THERE A SPECIAL TOOL?
  #5 (permalink)
Old 05-16-2008, 03:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I do not think you need any special tools, may be WD-40.
DO NOT FORGET TO REMOVE THE POWER FIRST!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replace Surface Element gaitherjohn@hotmail.com Oven Repair (including Ranges and Cooktops) 0 01-31-2008 09:56 AM
Need to replace heating element Nova Dryer Repair 0 01-05-2008 12:39 AM
How to replace Bake element? patchas Oven Repair (including Ranges and Cooktops) 2 12-29-2007 02:34 PM
How to replace heating element abernickle Oven Repair (including Ranges and Cooktops) 1 10-03-2007 07:34 PM
How to replace a heating element? bjordan2@msn.com Dryer Repair 3 09-12-2007 05:56 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
