| » Oven Sensor Issue |
Model Number: 8301983 Brand: Kitchen Aid Age: 5 - 10 years
Hi everyone, first time posting, I hope to include all information. I just purchased my first home with my new wife and there was a KitchenAid Electric Oven (and Stove) in the house.
I believe the Model # is 8301983 Rev. A After about a month of use, I got an E3 error that the Oven Sensor was not working. After checking your forums here, I ordered a part but by accident ordered the wrong part. When I got the 6inch oven sensor I clipped the connector from the oven and tried to splice the wires together. This did not work as it was the wrong sensor. Last week I ordered the correct sensor but now with the connector cut from the oven, I decided to clip it from the new part also. I just installed it and after turning the oven back on, I still received the same error. (just want to add I did use wire nuts on the exposed wires I tried to splice together) When I hit Bake, and then Start the oven will fire up, I hear what sounds like a fan going and after about 30 seconds, the error comes back up and everything shuts down. Any suggestions, I'm not very good with electric work but I would like to fix this without having to hire a pro in if possible. Thanks in advance! Ads By Google Related Models |
Your model number is not correct.
Kitchenaid numbers are usually a few letters followed by several numbers. Find your model number - AppliancePartsPros.com Does sound like it is a control board problem. Remove power from the unit and check where the sensor connects to the control board. Look for a cold solder joint or cracked board circuit trail. Cold solder joints are often a duller grey and/or have pin holes. Also if you gently wiggle a part on the component side of the board you may be able to see the part's leg move in the solder. A magnifying glass is useful when doing this. If you cannot find anything then the board is probably shot as it is giving a false error.
__________________
| Display Modes | |
| Temperature sensor issue | Stan Stevens | Oven Repair (including Ranges and Cooktops) | 3 | 06-15-2011 09:44 AM |
| GE Oven - F3 after replacing oven temp sensor | robjcici | Oven Repair (including Ranges and Cooktops) | 16 | 01-08-2011 03:38 PM |
| sensor issue vs electronic control | curiousjo | Oven Repair (including Ranges and Cooktops) | 0 | 09-24-2010 12:58 PM |
| Sensor touch pad or pcb issue? | JaniceD | Oven Repair (including Ranges and Cooktops) | 16 | 11-01-2009 12:19 PM |
| oven sensor question/WB21T10007 GE Oven Sensor | lynnmta | Oven Repair (including Ranges and Cooktops) | 0 | 07-18-2009 07:51 AM |
