Discuss
Sears Kenmore Pro Dual Fuel Range Problem Heating Up
 in
After setting the oven control knob to Bake and setting the temperature knob to the desired cooking temperature, the oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Sears Kenmore Pro Dual Fuel Range Problem Heating Up
  #1 (permalink)
Old 10-28-2012, 03:08 PM
Junior Member
akkelley3 is on a distinguished road
Default Sears Kenmore Pro Dual Fuel Range Problem Heating Up
Brand: Sears   Age: 1 - 5 years
After setting the oven control knob to Bake and setting the temperature knob to the desired cooking temperature, the oven will initially try to heat up, but after a minute or so, will display ERR code and stop. While it attempts to heat up,the displayed set temperature fluctuates and it beeps constantly. Is there a control board that needs replaced?
Ads By Google
  #2 (permalink)
Old 10-29-2012, 02:38 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Could be but you will need your model number.
Find your model number - AppliancePartsPros.com
__________________
  #3 (permalink)
Old 10-30-2012, 06:20 PM
Junior Member
Default Model number
The model number is 79079523603.
  #4 (permalink)
Old 10-31-2012, 05:00 AM
Senior Expert
APP Volunteer
Default
I cannot find any info as to what the "ERR" code means.
I would re-post your problem but this time include the model number.
__________________
  #5 (permalink)
Old 10-31-2012, 06:39 PM
Junior Member
Default
Okay I will. Thank you.
  #6 (permalink)
Old 11-01-2012, 03:08 AM
Senior Expert
APP Volunteer
Default
With luck someone else will be able to help but just in case no one does I would check the oven sensor. This is just a wild guess on my part.
See the below link, look at 7, 8, 20 and 21.
http://www.applianceaid.com/electric...air-topics.php
Also check where it connects to the control board.
Check that the connectors are clean.
Also check that where it connects for a cold solder joint. Cold solder joints are often a duller grey and/or have pin holes.
Perhaps gently wiggle the connectors on the parts side of the board while looking at the solder side to see if the connector legs move in the solder.
Check for hairline cracks across the copper tracks on the board.
A magnifying glass can be useful while doing this at least it is for my old eyes.
Most ovens switch back and forth between the bake and broil elements during preheat so check that both elements are OK.
Good luck and I will keep my fingers crossed that you will get better help.
__________________
  #7 (permalink)
Old 11-02-2012, 05:54 PM
Junior Member
Default
Thanks alot Denman, I will try your suggestions.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid dual fuel rANGE HAS pf RESET PROBLEM Oregonia Oven Repair (including Ranges and Cooktops) 0 06-22-2012 10:03 AM
kenmore pro dual fuel range overheating kenmoreprofails Oven Repair (including Ranges and Cooktops) 7 05-10-2012 04:37 AM
kenmore Dual Fuel Range - oven does not heat richardjefferson Oven Repair (including Ranges and Cooktops) 1 10-04-2010 01:09 AM
Kenmore Dual Fuel - OVEN NOT HEATING PROPERLY chaznsc Oven Repair (including Ranges and Cooktops) 2 05-25-2010 10:37 PM
Bosch Dual Fuel range Meat Probe problem jayhawk2685 Oven Repair (including Ranges and Cooktops) 0 08-22-2009 08:16 AM
