Discuss
Problem w/ Maytag oven's interia light stays on
 in
Problem w/ Maytag oven's interia light Recently the bulb burned out on our ten year old Maytag oven not sure
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Problem w/ Maytag oven's interia light stays on
  #1 (permalink)
Old 10-26-2012, 05:11 AM
Junior Member
Stevethebrain is on a distinguished road
Default Problem w/ Maytag oven's interia light stays on
Model Number: CRE9800C   Brand: Maytag   Age: 5 - 10 years
Recently the bulb burned out on our ten year old Maytag oven not sure of the exact model the owner's manuel has all these listed CRE9800C,CRE9600C,CHE9800B &CFE9000B.
I hate to amit this initialley I did'nt know how to remove this bulb and I did'nt turn off the breaker panel for oven (I know stupid mistake).
I removed the screws holding the light socket and pulled out the socket from the backplane of oven when doing this there was a spark and this turned off the breaker.
I now know the correct way of removing the light bulb cover it just screws off(actualley I tryed removing this cover first it was on there very tight and was concerned that I may break the cover so I decided to unscrew the whole socket).
Now I have a new bulb and it stays on even w/ oven door closed even w/ the switch on front of oven off bulb just stays on.
W/ socket removed from oven I checked the continuity of the socket's two terminals and have good continuity.
Any tips is appreciated.
STB
Ads By Google
Related Models
Maytag CRE9800CCB RANGE- S/C F/S ELE
Maytag CRE9800CCE RANGE- S/C F/S ELE
Maytag CRE9800CCM RANGE- S/C F/S ELE
Maytag CRE9800CDB RANGE- S/C F/S ELE
Maytag CRE9800CDE RANGE- S/C F/S ELE
Maytag CRE9800DDB RANGE- S/C F/S ELE
Maytag CRE9800DDE RANGE- S/C F/S ELE
Maytag CRE9800DDM RANGE- S/C F/S ELE
Maytag CRE9830BCB RANGE- S/C F/S ELE
Maytag CRE9830BCE RANGE- S/C F/S ELE
Maytag CRE9830BCM RANGE- S/C F/S ELE
Maytag CRE9830CDB RANGE- S/C F/S ELE
Maytag CRE9830CDE RANGE- S/C F/S ELE
Maytag CRE9830CDM RANGE- S/C F/S ELE
Maytag CRE9900ACB RANGE- S/C F/S ELE
Maytag CRE9900ACE RANGE- S/C F/S ELE
Admiral CREA200ACL RANGE- F/S STD ELE
Admiral CREA200ACW RANGE- F/S STD ELE
Admiral CREA300ACL RANGE- F/S STD ELE
Admiral CREA300ACW RANGE- F/S STD ELE
Admiral CREA400ACL RANGE- F/S STD ELE
Admiral CREA400ACW RANGE- F/S STD ELE
Admiral CREA450ACL RANGE- F/S STD ELE
Admiral CREA450ACW RANGE- F/S STD ELE
Admiral CREA600ACE RANGE- S/C F/S ELE
Admiral CREA600ACL RANGE- S/C F/S ELE
Admiral CREA600ACW RANGE- S/C F/S ELE
Admiral CREA650ACB RANGE- S/C F/S ELE
Admiral CREA650ACL RANGE- S/C F/S ELE
Admiral CREA650ACW RANGE- S/C F/S ELE
Admiral CREA750ACB RANGE- S/C F/S ELE
Admiral CREA750ACE RANGE- S/C F/S ELE
Admiral CREA750ACM RANGE- S/C F/S ELE
Frigidaire CREF342AS0 Dryer - Frigidaire/best Buy
Frigidaire CREF342AS1 Dryer - Frig/best Buy
Frigidaire CREF342AS2 Frigidaire/electric Dryer
Crosley CREF366FBA BRADA CANADA/ELECTRIC RANGE
Crosley CREF366FCA BRADA CANADA/ELECTRIC RANGE
Crosley CREF366FSA BRADA CANADA/ELECTRIC RANGE
Frigidaire CRER442AS0 Dryer - Frig/best Buy
Frigidaire CRER442AS1 Dryer - Frig/best Buy
Frigidaire CRER442AS2 Dryer - Frig/best Buy
Frigidaire CRER5700AS0 Dryer - Frig/best Buy
Frigidaire CRER5700AS1 Frigidaire/electric Dryer
Frigidaire CRER7900AS0 Dryer - Frig/best Buy
Frigidaire CRER7900AS1 Frigidaire/electric Dryer
Maytag CRG0560AAW Range - F/s Std Gas
Maytag CRG0760AAL RANGE- S/C F/S GAS
Maytag CRG0760AAW RANGE- S/C F/S GAS
Maytag CRG0860AAL RANGE- S/C F/S GAS
Maytag CRG0860AAW RANGE- S/C F/S GAS
Maytag CRG200 RANGE- F/S STD GAS
Maytag CRG200B RANGE- F/S STD GAS
Maytag CRG300 RANGE- F/S STD GAS
Maytag CRG300B RANGE- F/S STD GAS
Maytag CRG305 RANGE- F/S STD GAS
Maytag CRG350 RANGE- F/S STD GAS
Maytag CRG350B RANGE- F/S STD GAS
Maytag CRG355 RANGE- F/S STD GAS
Maytag CRG382 RANGE- F/S STD GAS
Maytag CRG383 RANGE- F/S STD GAS
Maytag CRG400 RANGE- F/S STD GAS
Maytag CRG400B RANGE- F/S STD GAS
Maytag CRG405 RANGE-F/S CONT CLEAN GAS
Maytag CRG500 RANGE- F/S STD GAS
Maytag CRG501 RANGE- F/S STD GAS
Maytag CRG502 RANGE- F/S STD GAS
Maytag CRG505 RANGE- F/S STD GAS
Maytag CRG560 RANGE- F/S STD GAS
Maytag CRG560A RANGE- F/S STD GAS
Maytag CRG583 RANGE-F/S CONT CLEAN GAS
Maytag CRG600 RANGE- F/S STD GAS
Maytag CRG601 RANGE- F/S STD GAS
Maytag CRG602 RANGE-F/S CONT CLEAN GAS
Maytag CRG700 RANGE- S/C F/S GAS
Maytag CRG705 RANGE- S/C F/S GAS
Maytag CRG7400AAL RANGE- F/S STD GAS
Maytag CRG7400AAW RANGE- F/S STD GAS
Maytag CRG7400BAL RANGE- F/S STD GAS
Maytag CRG7400BAW RANGE- F/S STD GAS
Maytag CRG7400CAE RANGE- F/S STD GAS
Maytag CRG7400CAL RANGE- F/S STD GAS
Maytag CRG7400CAW RANGE- F/S STD GAS
Maytag CRG750 RANGE- S/C F/S GAS
Maytag CRG7500AAE RANGE- F/S STD GAS
Maytag CRG7500AAL RANGE- F/S STD GAS
Maytag CRG7500AAW RANGE- F/S STD GAS
Maytag CRG7500CAE RANGE- F/S STD GAS
Maytag CRG7500CAL RANGE- F/S STD GAS
Maytag CRG7500CAW RANGE- F/S STD GAS
Admiral CRG7500CGE RANGE- F/S STD GAS
Admiral CRG7500CGW RANGE- F/S STD GAS
Maytag CRG755 RANGE- S/C F/S GAS
Maytag CRG760 RANGE- S/C F/S GAS
Maytag CRG7600AAL RANGE-F/S CONT CLEAN GAS
Maytag CRG7600AAW RANGE-F/S CONT CLEAN GAS
Maytag CRG760A RANGE- S/C F/S GAS
Maytag CRG7700AAL RANGE- F/S STD GAS
Maytag CRG7700AAW RANGE- F/S STD GAS
Maytag CRG7700BAL RANGE- F/S STD GAS
Maytag CRG7700BAW RANGE- F/S STD GAS
Maytag CRG7700CAL RANGE- F/S STD GAS
Maytag CRG7700CAW RANGE- F/S STD GAS
Maytag CRG783 RANGE- S/C F/S GAS
Maytag CRG800 RANGE- S/C F/S GAS
Maytag CRG805 RANGE- S/C F/S GAS
Maytag CRG8200AAL RANGE- F/S STD GAS
Maytag CRG8200AAW RANGE- F/S STD GAS
Maytag CRG8200BAL RANGE- F/S STD GAS
Maytag CRG8200BAW RANGE- F/S STD GAS
Maytag CRG8200CAL RANGE- F/S STD GAS
Maytag CRG8200CAW RANGE- F/S STD GAS
Maytag CRG8400AAL RANGE- F/S STD GAS
Maytag CRG8400AAW RANGE- F/S STD GAS
Maytag CRG860 RANGE- S/C F/S GAS
Maytag CRG8600AAB RANGE- S/C F/S GAS
Maytag CRG8600AAL RANGE- S/C F/S GAS
Maytag CRG8600AAW RANGE- S/C F/S GAS
Maytag CRG8600BAB RANGE- S/C F/S GAS
Maytag CRG8600BAL RANGE- S/C F/S GAS
  #2 (permalink)
Old 10-26-2012, 05:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi STB,
The correct and complete model number is very important. Hopefully the Model Number Locator will help you to find it.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 10-27-2012, 12:07 AM
Junior Member
Default
Gene should the light bulb socket have continuity between the two terminals?
I'll check the model #
STB
  #4 (permalink)
Old 10-29-2012, 10:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
If you removed the wires from the socket terminals then it should be no continuity.
__________________
  #5 (permalink)
Old 10-30-2012, 11:25 PM
Junior Member
Default
Gene yes I removed the wires from the socket and have continuitiy probablley ruined the socket when the hot wires contacted the backplane of the oven.
I looked at the locations for the model # still can't find the model # printed on the oven.
I can remove the socket and take a image of the socket w/ this image can you provide a part # so I can order a replacment socket?
Thanks STB
  #6 (permalink)
Old 10-30-2012, 11:26 PM
Junior Member
Default
having no continutiy w/out bulb makes sense I bet w/ a bulb and a good socket there will be continunity?
I looked at all 21 pages for the socket cound'nt find it.
Thanks STB
  #7 (permalink)
Old 10-31-2012, 04:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm afraid that the major problem caused by the short in the light socket is more than the damaged light socket.
How the oven and the surface burners will work with the wires disconnected from the light socket and insulated? Check all functions of the oven.
__________________
  #8 (permalink)
Old 11-01-2012, 12:08 AM
Junior Member
Default
Gene the oven functions exactly like it did before the short w/ light socket.
  #9 (permalink)
Old 11-01-2012, 04:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The best solution to get the correct light socket I believe is to take the old one to a local appliance parts store.
__________________
  #10 (permalink)
Old 11-03-2012, 06:35 AM
Junior Member
Default
Gene how much $ should I expect to give for a new socket?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven's do not work Jesse35 Oven Repair (including Ranges and Cooktops) 0 03-14-2011 11:10 AM
Light stays on Cody32 Refrigerator & Freezer Repair 0 12-14-2009 08:24 PM
Maytag Oven ON Light stays on Madmax Oven Repair (including Ranges and Cooktops) 1 04-28-2009 07:27 PM
Kenmore range - oven's bake element stays on nauran99 Oven Repair (including Ranges and Cooktops) 5 04-24-2009 09:16 AM
In Use Light Stays On byteme4111 Oven Repair (including Ranges and Cooktops) 0 07-10-2008 11:06 AM
