| » GE oven temps incorrect |
Model Number: JKP27WOP2WG Brand: GE Age: More than 10 years
This is a double wall oven (20 years old). Neither oven has correct temp when set at 400 degrees. One registers 360 degrees and the other 420 degrees. Is this something that can be reasonably repaired or should I plan on purchasing a new oven?
Hi.
See if you can find the owners manual. Look under temperature adjustments. The lower oven temperature can be adjusted at the back of the thermostat's knob. If the temperature is not fluctuating then you know it's 40*F colder- set it for 40*F more. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Incorrect oven temperature | cpkennedy | Oven Repair (including Ranges and Cooktops) | 6 | 12-20-2010 01:23 PM |
| GE Built-In Oven F2 Code Oven Temps Erratic & Over-Temp | herbl | Oven Repair (including Ranges and Cooktops) | 0 | 02-26-2010 09:08 AM |
| Incorrect oven temperature | cwren | Oven Repair (including Ranges and Cooktops) | 2 | 06-06-2008 12:41 PM |
| Oven has two temps, off, and max 500 + | ocappe | Oven Repair (including Ranges and Cooktops) | 4 | 11-14-2007 05:31 AM |
