Hi, i ran out of gas. After refilling, everything works except the oven bottom burner. The ignitor ticks a few times, the burner flames up all the way down the tube, then within 10 seconds the flames go out. If i leave on, the ignitor will click/tick lol few times and it will flame up for less than 10 sec. and again flame is out. The broiler works fine and stays lit. My question is, after looking at manual, does this sound like an ignitor issue, or the gas valve in bottom of the oven? thanks for any help. Oh also the only thing keeping me from removing the ignitor is one red wire attached/like soildered to ignitor. The wire seems to lead deep into wall/inner stove, and wouls require almost skining the thing to trace down. 2nd Question is, can i just cut this wire and wire nut the new wire back to it instead of taking the whole stove apart. Thanks again for any help.
