| » conversion |
Model Number: jgbp33det2ww Brand: GE Age: Less than 1 year
what do I need to convert this range to LP?
You'll need your tech sheet. Remove the lower drawer or broiler drawer and locate the regulator. To convert the regulator, remove the large hex nut in the center of the regulator. Remove the plastic pin under the cap and flip it 180*. You should be able to see “LP” on the flat side of the pin. Remove the surface burners and replace the four orifice spuds with the LP orifice spuds. The LP orifices have an”L” engraved on the top. There are different orifice sizes depending on the surface burner. You’ll need the tech sheet for the correct application. Use a ½” wrench and tighten the orifice hoods on the oven burners until snug. Open the air shutter on the oven burners to the full open position then adjust as needed. You may need to adjust the surface burners low flame setting. Check your tech sheet. The tech sheet should be located on the right or left side panel on the inside behind the lower drawer. The LP orifices probably came with the range so check near the tech sheet and on back of the range
__________________
Ricks Appliance Repair |
| Display Modes | |
| NG to LP Conversion Kit | Nora Hess | Oven Repair (including Ranges and Cooktops) | 0 | 08-10-2012 04:15 PM |
| NG-LP Conversion Kit | Nora Hess | Oven Repair (including Ranges and Cooktops) | 1 | 08-10-2012 04:11 PM |
| Nat to LP conversion | regie | Oven Repair (including Ranges and Cooktops) | 1 | 08-27-2011 03:51 AM |
| Nat. To Lp Conversion | jrcouldry | Oven Repair (including Ranges and Cooktops) | 1 | 02-21-2010 03:39 PM |
| Conversion to LP | chuchin51 | Oven Repair (including Ranges and Cooktops) | 4 | 03-01-2009 08:54 AM |
