Discuss
Oven and broiler elements will not heat
 in
Kenmore 790.96334504. Panel indicates oven is on and preheating. Stays in preheat mode. Neither element heats. Cleaning cycle does heat.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven and broiler elements will not heat
  #1 (permalink)
Old 10-17-2012, 02:18 PM
Junior Member
Mcritter is on a distinguished road
Default Oven and broiler elements will not heat
Brand: Kenmore   Age: 5 - 10 years
Ads By Google
  #2 (permalink)
Old 10-17-2012, 05:18 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Unplug the unit.
Open the control panel and using the multimeter check continuity between pins 9 (Gray) and 10 (Orange) at the control board.
If you read infinity - replace the control, if < then 1ohm - the door latch switch is closed and should be replaced Part number: 316405800
The control board Part number: 316557238
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 10-19-2012, 01:07 PM
Junior Member
Default
Checked the continuity between pins 9 & 10 on the control panel. Reading was infinity, which indicates control panel should be replaced. Put it back together (so we could use the stove while awaiting the part) and the oven operated normally. I allowed it to cool and turned it on again, and it again worked normally.
  #4 (permalink)
Old 10-19-2012, 03:09 PM
Expert
Default
Hi.
Possible bad connection at the control board.
Enjoy cooking without expenses.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven and broiler elements not turning on joelagreca Oven Repair (including Ranges and Cooktops) 0 01-25-2012 01:14 PM
Both new oven elements won't heat thomasvanderhoof Oven Repair (including Ranges and Cooktops) 7 10-22-2010 06:05 AM
Jenn-Air Oven and Broiler Elements Not Working DavidRG Oven Repair (including Ranges and Cooktops) 4 04-16-2010 09:54 PM
Oven & Broiler Elements Not Working dbau111 Oven Repair (including Ranges and Cooktops) 4 11-05-2008 05:27 PM
hotpoint oven baking elements and broiler elament dont shut off with themostat csansom Oven Repair (including Ranges and Cooktops) 0 04-15-2008 10:08 AM
