| » Whirlpool SB130PER4 Gas Wall oven doesn't heat |
Model Number: SB130PER4 Brand: Whirlpool Age: More than 10 years
Greetings,
I have a Whirlpool SB130PER4 Blanket-O-Flame wall oven in my house, that does not heat. When I turn it on, the ignitor glows bright orange, and I can smell gas, but it doesn't appear to light up inside the burner. I'm looking for advice on next steps I should take in troubleshooting the issue. * Should I test the ignitor (How do I check how much power it's pulling?) * Maybe the burner itself is bad? Any help y'all might be able to provide will be much appreciated. Thanks! Ads By Google Related Models |
Hi.
Almost every functional part for your oven is no longer available. Does the broil works? To check the amp draw of the ignitor you need to clamp on the amp meter over one ignitor's wire. The normal reading should be 3.2 - 3.6amp. If it's less - replace the ignitor Part number: 786324 Here are the breakdown diagrams and http://www.appliancepartspros.com/ma...sb130per4.html Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Whirlpool wall oven won't heat | JarodRay | Oven Repair (including Ranges and Cooktops) | 0 | 07-10-2012 10:23 PM |
| GE Wall Oven Won't heat up | tejyam@hotmail.com | Oven Repair (including Ranges and Cooktops) | 3 | 01-18-2012 04:19 PM |
| Wall oven will not heat/re-heat properly | dottavio | Oven Repair (including Ranges and Cooktops) | 0 | 01-07-2010 09:47 AM |
| Whirlpool Double Wall Oven Won't Heat... | DaveinMD | Oven Repair (including Ranges and Cooktops) | 2 | 12-02-2009 07:45 AM |
