Discuss
Frigidaire Double Wall Oven Upper No Broil Lower No Oven
 in
Hi Repair Pros I have a double wall oven set, and the upper will not broil and the lower will
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire Double Wall Oven Upper No Broil Lower No Oven
  #1 (permalink)
Old 10-14-2012, 12:50 PM
Junior Member
Jim Gaspar is on a distinguished road
Default Frigidaire Double Wall Oven Upper No Broil Lower No Oven
Model Number: PLEB30T8ACB   Brand: Frigidaire   Age: More than 10 years
Hi Repair Pros
I have a double wall oven set, and the upper will not broil and the lower will not bake.
I took off the top, and checked things out. I am pretty sure I need new relay boards for each, but before I buy them I wanted to verify.
The elements ohmed out per spec; you can actually do this from the top with the ovens off.
With the power on and the broiler or oven being tested also turned on at the control board, I got 240VAC accross the control relays for both the bad broiler and bad oven which of course if the difference in L1 and L2 and I assume this is because the relays are failed open. In contrast, the good broiler and oven both showed no voltage differential because the relays were closed and the elements generating heat.
Do you concur that I need to purchase both boards? Is this a rare event after only 10 years?
regards and thanks in advance for the response.
JimG
Ads By Google
Related Models
Frigidaire PLEB30T8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB30T8CCA Frigidaire/wall Oven
Frigidaire PLEB30T8CCB Frigidaire/electric Wall Oven
Frigidaire PLEB30T9DCA Frigidaire/electric Walloven
Frigidaire PLEB30T9DCB Frigidaire/wall Oven
Frigidaire PLEB30T9DCC Frigidaire/walloven
Frigidaire PLEB30T9FCA Frigidaire/wall Oven
Frigidaire PLEB30T9FCB Frigidaire/walloven
Frigidaire PLEB30T9FCC ELECTRIC OVEN
Frigidaire PLEB30T9FCD ELECTRIC OVEN
Frigidaire PLEB30T9FCE ELECTRIC OVEN
Frigidaire PLEC30S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECC Frigidaire/cooktop
Frigidaire PLEC36S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECC Frigidaire/cooktop
Frigidaire PLEF398ACA Frigidaire/range
Frigidaire PLEF398ACB Frigidaire/electric Range
Frigidaire PLEF398ACC Frigidaire/electric Range
Frigidaire PLEF398CCA Frigidaire/electric Range
Frigidaire PLEF398CCB Frigidaire/electric Range
Frigidaire PLEF398CCC Frigidaire/electric Range
Frigidaire PLEF398CCD Frigidaire/electric Range
Frigidaire PLEF398CCE Frigidaire/electric Range
Frigidaire PLEF398DCA Frigidaire/electric Range
Frigidaire PLEF398DCB Frigidaire/electric Range
Frigidaire PLEF398DCC Frigidaire/electric Range
Frigidaire PLEF398DCD Frigidaire/range
Frigidaire PLEF398DCE Frigidaire/range
Frigidaire PLEF398DCH Frigidaire/range
Frigidaire PLEF398DCJ Frigidaire/electric Range
Frigidaire PLEF489ACA Frigidaire/electric Range
Frigidaire PLEF489ACB Frigidaire/electric Range
Frigidaire PLEF489ACC Frigidaire/electric Range
Frigidaire PLEF489ACD Frigidaire/electric Range
Frigidaire PLEF489CCA Frigidaire/electric Range
Frigidaire PLEF489CCB Frigidaire/electric Range
Frigidaire PLEF489CCC Frigidaire/electric Range
Frigidaire PLEF489CCD Frigidaire/electric Range
Frigidaire PLEF489CCE Frigidaire/electric Range
Frigidaire PLEF489CCF Frigidaire/electric Range
Frigidaire PLEF489CCG Frigidaire/electric Range
Frigidaire PLEF489CCH ELECTRIC RANGE
Frigidaire PLEF489GCA ELECTRIC RANGE
Frigidaire PLEFM399DCA Frigidaire/electric Range
Frigidaire PLEFM399DCB Frigidaire/electric Range
Frigidaire PLEFM399DCC Frigidaire/electric Range
Frigidaire PLEFM399DCD Frigidaire/range
Frigidaire PLEFMZ99ECA Frigidaire/range
Frigidaire PLEFMZ99ECC Frigidaire/range
Frigidaire PLEFMZ99ECE Frigidaire/electric Range
Frigidaire PLEFMZ99ECF Frigidaire/electric Range
Frigidaire PLEFMZ99ECG Frigidaire/range
Frigidaire PLEFMZ99ECJ Frigidaire/electric Range
Frigidaire PLEFMZ99ECK Frigidaire/range
Frigidaire PLEFMZ99ECM ELECTRIC RANGE
Frigidaire PLEFMZ99ECN ELECTRIC RANGE
Frigidaire PLEFMZ99GCA ELECTRIC RANGE
Frigidaire PLEFMZ99GCB ELECTRIC RANGE
Frigidaire PLEFMZ99GCC ELECTRIC RANGE
Frigidaire PLEFMZ99GCD ELECTRIC RANGE
Frigidaire PLEFMZ99GCE ELECTRIC RANGE
Frigidaire PLEFZ398ECA Frigidaire/electric Range
Frigidaire PLEFZ398ECB Frigidaire/electric Range
Frigidaire PLEFZ398ECC Frigidaire/range
Frigidaire PLEFZ398ECD Frigidaire/electric Range
Frigidaire PLEFZ398ECE Frigidaire/range
Frigidaire PLEFZ398ECF Frigidaire/range
Frigidaire PLEFZ398GCA ELECTRIC RANGE
Frigidaire PLEFZ398GCB ELECTRIC RANGE
Frigidaire PLEFZ398GCC ELECTRIC RANGE
Frigidaire PLES389ACA Frigidaire/electric Range
Frigidaire PLES389ACB Frigidaire/electric Range
Frigidaire PLES389ACC Frigidaire/electric Range
Frigidaire PLES389ACD Frigidaire/electric Range
Frigidaire PLES389CCA Frigidaire/electric Range
Frigidaire PLES389CCB Frigidaire/electric Range
Frigidaire PLES389CCC Frigidaire/electric Range
Frigidaire PLES389DCA Frigidaire/electric Range
Frigidaire PLES389DCB Frigidaire/electric Range
Frigidaire PLES389DCC Frigidaire/electric Range
Frigidaire PLES389DCD Frigidaire/electric Range
Frigidaire PLES389DCE Frigidaire/electric Range
Frigidaire PLES389ECB Frigidaire/electric Range
Frigidaire PLES389ECC Frigidaire/electric Range
Frigidaire PLES389ECD Frigidaire/electric Range
Frigidaire PLES389ECE Frigidaire/range
Frigidaire PLES389ECF Frigidaire/electric Range
Frigidaire PLES389ECG Frigidaire/electric Range
Frigidaire PLES389ECH Frigidaire/electric Range
Frigidaire PLES389ECI ELECTRIC RANGE
Frigidaire PLES389ECJ ELECTRIC RANGE
Frigidaire PLES399ECB Frigidaire/electric Range
Frigidaire PLES399ECC Frigidaire/electric Range
Frigidaire PLES399ECD Frigidaire/range
Frigidaire PLES399ECE Frigidaire/electric Range
Frigidaire PLES399ECF Frigidaire/electric Range
Frigidaire PLES399ECG Frigidaire/electric Range
Frigidaire PLES399ECH ELECTRIC RANGE
Frigidaire PLES399ECI ELECTRIC RANGE
Frigidaire PLEW27S3ECA Frigidaire/warmer Drawer
Frigidaire PLEW27S3FCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3ACA Frigidaire/warmer Drawer
Frigidaire PLEW30S3CCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3DCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3DCB Frigidaire/warmer Drawer
Frigidaire PLEW30S3FCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3FCB Frigidaire/warmer Drawer
Frigidaire PLFH1779GS0 FREEZER
Frigidaire PLFH1779GS1 FREEZER
Frigidaire PLFH1779GS2 FREEZER
Frigidaire PLFH1779GS3 FREEZER
Frigidaire PLFU1777DS0 Frigidaire/freezer
Frigidaire PLFU1777DS1 Frigidaire/freezer
Frigidaire PLFU1777DS2 Frigidaire/freezer
Frigidaire PLFU1778ES0 Frigidaire/freezer
Frigidaire PLFU1778ES1 Frigidaire/freezer
Frigidaire PLFU1778ES2 Frigidaire/freezer
Frigidaire PLFU1778ES3 FREEZER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Double Oven, Lower won't heat wytgold Dryer Repair 0 04-14-2011 03:51 PM
Dacor Double Wall Oven-replace lower oven relay board CatsR Oven Repair (including Ranges and Cooktops) 3 01-28-2011 07:29 AM
old frigidaire double wall oven thermostat philtwo Oven Repair (including Ranges and Cooktops) 2 11-18-2010 12:09 PM
Frigidaire Double Wall Oven (Electric) A87CEO Oven Repair (including Ranges and Cooktops) 1 11-17-2009 09:24 AM
GE Electric Double Wall Oven won't bake or broil tjp Oven Repair (including Ranges and Cooktops) 1 01-21-2009 07:15 AM
