| » Kenmore Stove-broiler and bake element wont come on |
Model Number: 790.96129401 Brand: Kenmore Age: 5 - 10 years
Hello,
I hope someone can help me with this. My oven was working fine last night and then this morning when I went to cook breakfast neither element would come on. The buttons all worked like normal, the clock, preheat light...everything, even the click from the clock panel when you turn it on. All the range top burners are fine. My husband is pretty handy and has an electric tester but he just needs some direction. Boy, it seems like one thing after another these days! I hope someone can help us. Thanks in advance, Debbie Ads By Google Related Models |
Parts for Kenmore Range 79096129401 - AppliancePartsPros.com Here is the wiring diagram. http://manuals.frigidaire.com/prodin.../316417705.pdf Do the surface elements work? If not try flipping the breaker off/on slowly a couple times. If they work. does the unit stay in pre-heat or does it show that the oven is ready? If it shows that it is ready it could be an oven sensor problem. If it stays in pre-heat, unplug the unit and check the wires to the elements and control board. If all OK odds are that the control board is toast.
__________________
Thanks so much for your reply!
What exactly are we suppose to be looking for when we inspect the wiring?
You are looking to see if any of the wires has overheated or burned off. If it turns out to be the control board is that something that we can replace ourselves? Yes if everything looks OK then I would replace the control board. Be sure the unit is unplugged when working on it, 240 volts is lethal.
__________________
Ok, we checked the wiring and it looks ok. He put an electric tester on it and followed these instructions: Kenmore Range
Nothing registered on the tester in both cases so I ordered the control board from the Appliances Pro place. I will let you know if that takes care of it. I sure do hope so. Thanks again for your help. |
| Display Modes | |
| broiler and bake element not working | rangerepair | Oven Repair (including Ranges and Cooktops) | 11 | 02-02-2012 03:26 PM |
| oven element/broiler element not working stove top is | MD110772 | Oven Repair (including Ranges and Cooktops) | 3 | 07-05-2011 01:23 AM |
| Broiler element comes on instead of Bake | mstriker250 | Oven Repair (including Ranges and Cooktops) | 3 | 01-26-2011 05:32 PM |
| Kenmore Gas Range bake/broiler wont work | stillinkent | Oven Repair (including Ranges and Cooktops) | 1 | 11-18-2009 04:48 PM |
| Kenmore Gas oven. Stove top lights, but oven and broiler wont | diggn89 | Oven Repair (including Ranges and Cooktops) | 1 | 08-27-2008 06:43 PM |
