Discuss
Old Tappan Double Oven - bottom won't heat up
 in
I just rented a house and I was told the old oven worked. It's a double oven model. A gas
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Old Tappan Double Oven - bottom won't heat up
  #1 (permalink)
Old 10-14-2012, 12:28 PM
Junior Member
TigerLily5 is on a distinguished road
Default Old Tappan Double Oven - bottom won't heat up
Model Number: 72-3657-23-12   Brand: Tappan   Age: More than 10 years
I just rented a house and I was told the old oven worked. It's a double oven model. A gas Tappan 72-3657-23-12.
The top oven works fine, the range works fine. The bottom oven light comes on but the oven itself is not heating up.
It was working up until the house became empty and the workers were moving things around to paint, etc.
Any ideas on what the culprit could be?
Ads By Google
Related Models
Frigidaire 72-3657-23-12 Tap(v8) / Gas Range
Frigidaire 72-3657-23-13 Tap(v2) / Gas Range
Frigidaire 72-3657-66-01 Tap(v3) / Gas Range
Frigidaire 72-3657-66-02 Tap(v6) / Gas Range
Frigidaire 72-3657-66-03 Tap(v3) / Gas Range
Frigidaire 72-3657-66-04 Tap(v6) / Gas Range
Frigidaire 72-3657-66-05 Tap(v3) / Gas Range
Frigidaire 72-3657-66-06 Tap(v9) / Gas Range
Frigidaire 72-3657-66-07 Tap(v3) / Gas Range
Frigidaire 72-3657-66-08 Tap(v3) / Gas Range
Frigidaire 72-3657-66-09 Tap(v9) / Gas Range
Frigidaire 72-3657-66-10 Tap(v3) / Gas Range
Frigidaire 72-3657-66-11 Tap(v6) / Gas Range
Frigidaire 72-3657-66-12 Tap(v9) / Gas Range
Frigidaire 72-3657-66-13 Tap(v3) / Gas Range
Frigidaire 72-3662-00-01 Tap(v1) / Gas Range
Frigidaire 72-3662-23-01 Tap(v2) / Gas Range
Frigidaire 72-3977-00-01 Tap(v1) / Gas Range
Frigidaire 72-3977-00-02 Tap(v4) / Gas Range
Frigidaire 72-3977-00-03 Tap(v7) / Gas Range
Frigidaire 72-3977-00-04 Tap(v10) / Gas Range
Frigidaire 72-3977-00-05 Tap(v1) / Gas Range
Frigidaire 72-3977-00-06 Tap(v4) / Gas Range
Frigidaire 72-3977-00-07 Tap(v1) / Gas Range
Frigidaire 72-3977-00-08 Tap(v7) / Gas Range
Frigidaire 72-3977-00-09 Tap(v1) / Gas Range
Frigidaire 72-3977-00-10 Tap(v7) / Gas Range
Frigidaire 72-3977-23-01 Tap(v2) / Gas Range
Frigidaire 72-3977-23-02 Tap(v5) / Gas Range
Frigidaire 72-3977-23-03 Tap(v8) / Gas Range
Frigidaire 72-3977-23-04 Tap(v11) / Gas Range
Frigidaire 72-3977-23-05 Tap(v2) / Gas Range
Frigidaire 72-3977-23-06 Tap(v5) / Gas Range
Frigidaire 72-3977-23-07 Tap(v2) / Gas Range
Frigidaire 72-3977-23-08 Tap(v8) / Gas Range
Frigidaire 72-3977-23-09 Tap(v2) / Gas Range
Frigidaire 72-3977-23-10 Tap(v8) / Gas Range
Frigidaire 72-3977-66-01 Tap(v3) / Gas Range
Frigidaire 72-3977-66-02 Tap(v6) / Gas Range
Frigidaire 72-3977-66-03 Tap(v9) / Gas Range
Frigidaire 72-3977-66-04 Tap(v12) / Gas Range
Frigidaire 72-3977-66-05 Tap(v3) / Gas Range
Frigidaire 72-3977-66-06 Tap(v6) / Gas Range
Frigidaire 72-3977-66-07 Tap(v3) / Gas Range
Frigidaire 72-3977-66-08 Tap(v9) / Gas Range
Frigidaire 72-3977-66-09 Tap(v3) / Gas Range
Frigidaire 72-3977-66-10 Tap(v9) / Gas Range
Frigidaire 72-3981-00-01 Tap(v1) / Gas Range
Frigidaire 72-3981-00-02 Tap(v1) / Gas Range
Frigidaire 72-3981-00-03 Tap(v3) / Gas Range
Frigidaire 72-3981-00-04 Tap(v1) / Gas Range
Frigidaire 72-3981-00-05 Tap(v1) / Gas Range
Frigidaire 72-3981-00-06 Tap(v3) / Gas Range
Frigidaire 72-3981-00-07 Tap(v1) / Gas Range
Frigidaire 72-3981-00-08 Tap(v1) / Gas Range
Frigidaire 72-3981-23-01 Tap(v2) / Gas Range
Frigidaire 72-3981-23-02 Tap(v2) / Gas Range
Frigidaire 72-3981-23-03 Tap(v4) / Gas Range
Frigidaire 72-3981-23-04 Tap(v2) / Gas Range
Frigidaire 72-3981-23-05 Tap(v2) / Gas Range
Frigidaire 72-3981-23-06 Tap(v4) / Gas Range
Frigidaire 72-3981-23-07 Tap(v2) / Gas Range
Frigidaire 72-3981-23-08 Tap(v2) / Gas Range
Frigidaire 72-3989-00-01 Tap(v1) / Gas Range
Frigidaire 72-3989-00-02 Tap(v4) / Gas Range
Frigidaire 72-3989-00-03 Tap(v1) / Gas Range
Frigidaire 72-3989-00-04 Tap(v1) / Gas Range
Frigidaire 72-3989-00-05 Tap(v4) / Gas Range
Frigidaire 72-3989-00-06 Tap(v7) / Gas Range
Frigidaire 72-3989-23-01 Tap(v2) / Gas Range
Frigidaire 72-3989-23-02 Tap(v5) / Gas Range
Frigidaire 72-3989-23-03 Tap(v2) / Gas Range
Frigidaire 72-3989-23-04 Tap(v2) / Gas Range
Frigidaire 72-3989-23-05 Tap(v5) / Gas Range
Frigidaire 72-3989-23-06 Tap(v8) / Gas Range
Frigidaire 72-3989-66-01 Tap(v3) / Gas Range
Frigidaire 72-3989-66-02 Tap(v6) / Gas Range
Frigidaire 72-3989-66-03 Tap(v3) / Gas Range
Frigidaire 72-3989-66-04 Tap(v3) / Gas Range
Frigidaire 72-3989-66-05 Tap(v6) / Gas Range
Frigidaire 72-3989-66-06 Tap(v9) / Gas Range
Frigidaire 72-4256-00-01 Tap(v1)
Frigidaire 72-4256-00-02 Tap(v3)
Frigidaire 72-4256-00-03 Tap(v5)
Frigidaire 72-4256-23-01 Tap(v2)
Frigidaire 72-4256-23-02 Tap(v4)
Frigidaire 72-4256-23-03 Tap(v6)
Frigidaire 72-7657-00-02 Tap(v7) / Gas Range
Frigidaire 72-7657-00-03 Tap(v7) / Gas Range
Frigidaire 72-7657-00-04 Tap(v10) / Gas Range
Frigidaire 72-7657-00-05 Tap(v4) / Gas Range
Frigidaire 72-7657-00-06 Tap(v10) / Gas Range
Frigidaire 72-7657-00-07 Tap(v4) / Gas Range
Frigidaire 72-7657-00-08 Tap(v4) / Gas Range
Frigidaire 72-7657-00-09 Tap(v10) / Gas Range
Frigidaire 72-7657-23-01 Tap(v8) / Gas Range
Frigidaire 72-7657-23-02 Tap(v11) / Gas Range
Frigidaire 72-7657-23-03 Tap(v8) / Gas Range
Frigidaire 72-7657-23-04 Tap(v11) / Gas Range
Frigidaire 72-7657-23-05 Tap(v5) / Gas Range
Frigidaire 72-7657-23-06 Tap(v11) / Gas Range
Frigidaire 72-7657-23-07 Tap(v5) / Gas Range
Frigidaire 72-7657-23-08 Tap(v5) / Gas Range
Frigidaire 72-7657-23-09 Tap(v11) / Gas Range
Frigidaire 72-7657-66-01 Tap(v9) / Gas Range
Frigidaire 72-7657-66-02 Tap(v12) / Gas Range
Frigidaire 72-7657-66-03 Tap(v9) / Gas Range
Frigidaire 72-7657-66-04 Tap(v12) / Gas Range
Frigidaire 72-7657-66-05 Tap(v6) / Gas Range
Frigidaire 72-7657-66-06 Tap(v12) / Gas Range
Frigidaire 72-7657-66-07 Tap(v6) / Gas Range
Frigidaire 72-7657-66-08 Tap(v6) / Gas Range
Frigidaire 72-7657-66-09 Tap(v12) / Gas Range
Frigidaire 72-7977-00-01 Tap(v13) / Gas Range
Frigidaire 72-7977-00-02 Tap(v16) / Gas Range
Frigidaire 72-7977-00-03 Tap(v19) / Gas Range
Frigidaire 72-7977-00-04 Tap(v22) / Gas Range
Frigidaire 72-7977-00-05 Tap(v7) / Gas Range
Frigidaire 72-7977-00-06 Tap(v10) / Gas Range
Frigidaire 72-7977-00-07 Tap(v4) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tappan Double Oven Top Won't Heat dewwars Oven Repair (including Ranges and Cooktops) 2 04-20-2012 08:11 AM
Tappan Double Oven Range barbeara13 Oven Repair (including Ranges and Cooktops) 2 07-06-2011 04:15 PM
old tappan tappan double oven bottom turns on top oven wont jcole9969 Oven Repair (including Ranges and Cooktops) 9 02-28-2011 08:17 AM
Tappan double oven keysrose Oven Repair (including Ranges and Cooktops) 1 07-02-2010 04:41 PM
Caloric double oven/bottom oven doesn't heat kj0505 Oven Repair (including Ranges and Cooktops) 1 12-10-2008 09:14 AM
