| » Fan runs continuous |
Model Number: GLES389FSB Brand: Frigidaire Age: 1 - 5 years
Replaced wiring harness 318224945 now fan runs continuous. Swapped wires one for one color for color except where both wires were same color to a sensor or switch so as not to misswire. Would it make a difference on a sensor or switch if wires of same color were switched?
Here is the wiring diagram
http://manuals.frigidaire.com/prodin.../318271934.pdf Would it make a difference on a sensor or switch if wires of same color were switched? It should not make any difference as long as it is a two wire switch or sensor. There is a possibility that it could be a 3 wire switch and you have it on the normally closed instead of normally open or vice versa.
__________________
| Display Modes | |
| Continuous Running | ibewsparky | Refrigerator & Freezer Repair | 3 | 12-22-2010 05:29 AM |
| Continuous spark | ranger61 | Oven Repair (including Ranges and Cooktops) | 0 | 10-07-2010 06:51 PM |
| Continuous sparking | johnmf | Oven Repair (including Ranges and Cooktops) | 0 | 05-10-2009 11:02 AM |
| continuous spark | tjneff | Oven Repair (including Ranges and Cooktops) | 1 | 03-12-2009 04:48 AM |
| Continuous Buzzer | grandfather | Dryer Repair | 0 | 02-18-2009 11:14 AM |
