Range element keeps getting hot
Right front element stays hot. I have to turn breaker off to shut down. Other 3 elements will not get hot.
It may be part of the following recall
Frigidaire and Electrolux ICON Electric Smoothtop Cooktops and Slide-In Ranges Recalled Due to Fire Hazard |
Cook top heats up by itself
Quote:
1 Attachment(s)
Parts for Frigidaire GLES389FSB Range - AppliancePartsPros.com See the attachment for the wiring diagram. I am assuming that the oven works OK. Unplug the unit and check the wiring to the element controls and from them to the terminal strip. If all OK I would disconnect the right front element and see if the other elements now work. If that does nothing disconnect the control/board for that element. Be very careful that the unit is unplugged when working on it and that nothingcan short out when you are testing it. This is a fairly complicated unit and may be best left to a pro. A manual is available for purchase at the following site but is for stand alone units not a slide in unit. The sections on the element controls is the same though. http://appliancejunk.com/forums/index.php |
| All times are GMT -7. The time now is 07:49 PM. |
