gas range igniter will not turn off
I have a frigidaire gas range stove model number: FGF378WCCA
The igniter sparks continuously. With the range lit, and with the knob in the off position. I have replaced the module - MFG Part Number 316135702 - and it did not resolve the issue. when I look at the wiring diagram there seems to be only one switch between the hot lead and the module. it appears to be the switch controlled by the knob. do you think that I should replace this part: MFG Part Number 316032000? any other input or suggestions? |
Hi.
You are right - replace the burner switch Part number: 316032000 Here are the breakdown diagrams and Burner parts for Frigidaire FGF378WCCA - AppliancePartsPros.com Post the results. Simon. |
| All times are GMT -7. The time now is 12:28 PM. |
