| » Had mini-explosions, replaced igniter, now gas but no ignition |
Model Number: 31FN-2KX-ON Brand: Magic Chef Age: More than 10 years
We were having mini-explosions in our single burner oven, then no lighting at all. I replaced the igniter and now the igniter glows very brightly and I hear and smell gas, but no ignition after one minute so I turn it off.
Could this be from igniter no being far enough in? It didn't go in quite as far as the previous one. When it did light before, I did notice a hole in the burner pipe where flame would come out halfway down the pipe. Could the extra hole reduce the pressure at the ignition point? Ads By Google Related Models Last edited by jmastrus : 10-12-2012 at 08:00 AM. |
Hi.
Try to understand why the new ignitor is not mounted the same way as the old one. Would you post a picture of the burner and ignitor? That will help a lot. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
I will take a poicture when I get home tonight.
When I inserted the new igniter from the rear of the stove, it didn't go in as far as the old one and the metal box cover had no clearance. Last night I removed the oven floor and flame spreader and was able to wiggle the igniter in a bit more pulling it from the inside, but then I broke the tip of the igniter and had to order a new one. I suspect the igniter may not have been in far enough? The gas hissing started very quickly when the igniter was in (before I wiggled it in further), but the burner didn't ignite. There is a burn through about halfway down the burner tube. Not huge, but could that reduce the pressue of the gas at the ignition site? Is replacing the burner tube difficult? Thanks for your help! |
| Display Modes | |
| Haier mini fridge doesn't turn on (replaced motor protector) | LeftyAce | Refrigerator & Freezer Repair | 4 | 09-06-2012 07:00 PM |
| Gas smell and mini-explosions in oven when starting | dbodz | Oven Repair (including Ranges and Cooktops) | 0 | 05-20-2012 02:58 PM |
| Just replaced failed igniter switch on Stove, now igniter on before gas flowing | Isotonic | Oven Repair (including Ranges and Cooktops) | 0 | 03-19-2011 11:14 AM |
| Mini explosions | lindakids | Oven Repair (including Ranges and Cooktops) | 1 | 01-31-2008 12:02 PM |
| Gas Oven Mini-Explosions | SJS | Oven Repair (including Ranges and Cooktops) | 1 | 01-01-2008 03:50 PM |
