Discuss
How to DISSABLE Jenn-Air Gas Cooktop Downdraft Fan
 in
I have a 48" Jen Air gas cooktop with the BBQ and the 4 gas burners and the downdraft. The
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » How to DISSABLE Jenn-Air Gas Cooktop Downdraft Fan
  #1 (permalink)
Old 10-06-2012, 11:18 AM
Junior Member
rick99 is on a distinguished road
Default How to DISSABLE Jenn-Air Gas Cooktop Downdraft Fan
Brand: Jenn-Air   Age: 1 - 5 years
The downdraft is basically useless because it is really not powerful enough to remove all the smoke from the BBQ and also reduces the flame size of the nearby burners when you are using the fan.
Finally after a few years of this I decided to install an above 1200CFM fan which has solved ALL MY PROBLEMS!!! It is FANTASTIC!
Unfortunately when I use the BBQ it still turns on the downdraft Fan. If I unplug the electrical connection from the fan it turns off the fan...Yay!!! BUT...it also turns off the igniters! BOO!!!
Is there an easy way to just disable the FAN only without a lot of modifications? Has anyone done this before?
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Instructions for replacing Broken Glass on Jenn Air downdraft Electric cooktop davis23 Oven Repair (including Ranges and Cooktops) 0 04-21-2012 11:47 AM
Jenn Air Downdraft Fan stays on ThatcherDeane Oven Repair (including Ranges and Cooktops) 1 12-24-2010 05:34 PM
Jenn Air downdraft not working Wolf1281 Oven Repair (including Ranges and Cooktops) 1 12-13-2010 08:55 AM
Jenn-Air downdraft problem barmstrong@aarons-inc.com Oven Repair (including Ranges and Cooktops) 1 03-17-2010 02:20 PM
Jenn-Air JED8345 Downdraft - Burners Out HXDLSATTY Oven Repair (including Ranges and Cooktops) 0 11-20-2009 07:19 AM
